trev10 Offline
#1 Posted : Saturday, 26 April 2008 2:50:54 AM(UTC)
trev10
Guys,
I have been looking at the TH400 supplied to me and trying to figure out why the speedo gear drive is not spinning when I have the car on jack and in gear etc. I have removed the cable housing and 43T gear and taken the picture below. Am I missing the main drive gear which I figured is supposed to go on the main shaft? If so what is required to fit one and do I have to drop the trans etc or can I just remove the rear housing section in the car.
I intend to run 15x7 cragars with 235/60/15 tyres (663 mm), 3.08 diff. As I said, the current gear is 43T. What would best suit my application.
Thanks in advance
Trev...
antoni Offline
#2 Posted : Saturday, 26 April 2008 5:49:30 AM(UTC)
antoni
Hi can do do it in car, need to pull ex housing and fit gear and clip.
will look up gear size that may work.
tony
antoni Offline
#3 Posted : Saturday, 26 April 2008 6:23:01 AM(UTC)
antoni
Hi only got part number for drive gear 8629548 ( holden) in the T400 parts box gears from 15 to 18. try 17?
The driven gear 40 teeth for 3:08 and 35 teeth for 2:60 diff. sle vb commie book.
Tony
trev10 Offline
#4 Posted : Thursday, 12 June 2008 5:42:59 PM(UTC)
trev10
Guys,
The new gear and clip has arived. Is there any secret to fitting these? Does the clip go in from the front or rear of the gear. Looks like the clip goes in first(due to the small locating hole in the main shaft) then the gear slides over the t
HZute-efi-VS5L Offline
#5 Posted : Thursday, 12 June 2008 5:55:08 PM(UTC)
HZute-efi-VS5L
hey trev. sorry im not to sure about how to fit it. but where where you able to buy the new gear and clip from? are parts for the t400 still avaiable?
jason
www.stickthisdecals.com.au
trev10 Offline
#6 Posted : Thursday, 12 June 2008 6:06:30 PM(UTC)
trev10
Jason,
I bought the box through Chevpower in Perth and their supplier is Eagle auto spares. The packaging for the gear/clip etc had eagle auto spares stickers on it.
Hope this helps.
Trev...
#7 Posted : Tuesday, 17 June 2008 11:24:26 PM(UTC)
Im probably a bit late now but you will most likely find the gear somewhere up the shaft and the clip in the bottom of the extension housing when you remove it.
#8 Posted : Tuesday, 17 June 2008 11:24:26 PM(UTC)
I'm probably a bit late now but you will most likely find the gear somewhere up the shaft and the clip in the bottom of the extension housing when you remove it.
#9 Posted : Wednesday, 18 June 2008 5:42:01 AM(UTC)
HZute-efi-VS5L
thanks for that trev will add it to my list of supliers =)
jason
