hi ...ive got some 253 engines (4 of them).what can i use to build up a 308? i know you cant use the pistons or crank....but what about heads lifters pushrods and all the other stuff?
any advice would be appreciated....jim |
Jim in Adelaide.. |
you can use heads, conrods, crank, and all the valvegear, sump, pickup, oil system manifold.
In cubes we trust.
thankz boom...i appreciate your help,ive read here you cant use the crank thou? i hope i can as i have 3 of them ,,something about the counterwieght?even so you,ve saved me lots of bucks ...thank you very much...jim
you can use the crank, it is lighter than the 308 crank, so get it balanced. if not get a 308 crank.
In cubes we trust.
Jim, what engine numbers are the 253's?, you may have a rarer one that someone may want for $$$ to go toward your 308.
He who hesitates, -Masturbates. |
Jim, what engine numbers are the 253s?, you may have a rarer one that someone may want for $$$ to go toward your 308.
Don't use the 253 crank in a 308. Get a 308 one. They are cheap as chips.
Dont use the 253 crank in a 308. Get a 308 one. They are cheap as chips.
i was just explaining that he can use it and it fits. obviously, with the extra weight of the pistons, the rotating assembly will try to shake itself apart.
In cubes we trust.
Which means you can't use it, but you are right it does fit. There are 2 x types of cranks as well - rope rear main and neoprene rear main. If you need a 308 crank i'd probably have one here.
_______________________________________________________ If |
Which means you cant use it, but you are right it does fit. There are 2 x types of cranks as well - rope rear main and neoprene rear main. If you need a 308 crank id probably have one here.
_______________________________________________________ If we |
Thanxz for that..Adam...Boom..Byron you guys are great for taking the time to help out people..i really appreciate it!!!!!!!! im going to go the 308 crank way cause of the balancing thing..($),so ill try sell/swap a 253 for one .. ps**** Byron which st
NSW
damn thats a long walk!!thanxz Byron |
Jim in Adelaide.. |
