#1 Posted : Sunday, 27 April 2008 9:13:28 PM(UTC)
hi ...ive got some 253 engines (4 of them).what can i use to build up a 308?
i know you cant use the pistons or crank....but what about heads lifters pushrods and all the other stuff?
any advice would be appreciated....jim
boom Offline
#2 Posted : Sunday, 27 April 2008 11:28:23 PM(UTC)
boom
you can use heads, conrods, crank, and all the valvegear, sump, pickup, oil system
manifold.
In cubes we trust.
#3 Posted : Monday, 28 April 2008 12:33:01 AM(UTC)
thankz boom...i appreciate your help,ive read here you cant use the crank thou?
i hope i can as i have 3 of them ,,something about the counterwieght?even so you,ve saved me lots of bucks ...thank you very much...jim
boom Offline
#4 Posted : Monday, 28 April 2008 1:01:57 AM(UTC)
boom
you can use the crank, it is lighter than the 308 crank, so get it balanced. if not get a 308 crank.
In cubes we trust.
adam PERTH Offline
#5 Posted : Monday, 28 April 2008 1:30:33 AM(UTC)
adam PERTH
Jim, what engine numbers are the 253's?, you may have a rarer one that someone may want for $$$ to go toward your 308.
adam PERTH Offline
#6 Posted : Monday, 28 April 2008 1:30:33 AM(UTC)
adam PERTH
Jim, what engine numbers are the 253s?, you may have a rarer one that someone may want for $$$ to go toward your 308.
#7 Posted : Monday, 28 April 2008 3:07:21 AM(UTC)
Don't use the 253 crank in a 308. Get a 308 one. They are cheap as chips.
#8 Posted : Monday, 28 April 2008 3:07:21 AM(UTC)
Dont use the 253 crank in a 308. Get a 308 one. They are cheap as chips.
boom Offline
#9 Posted : Monday, 28 April 2008 3:09:20 AM(UTC)
boom
i was just explaining that he can use it and it fits. obviously, with the extra weight of the pistons, the rotating assembly will try to shake itself apart.
In cubes we trust.
#10 Posted : Monday, 28 April 2008 3:13:29 AM(UTC)
Which means you can't use it, but you are right it does fit. There are 2 x types of cranks as well - rope rear main and neoprene rear main. If you need a 308 crank i'd probably have one here.
If
#11 Posted : Monday, 28 April 2008 3:13:29 AM(UTC)
Which means you cant use it, but you are right it does fit. There are 2 x types of cranks as well - rope rear main and neoprene rear main. If you need a 308 crank id probably have one here.
If we
#12 Posted : Monday, 28 April 2008 6:53:58 AM(UTC)
Thanxz for that..Adam...Boom..Byron
you guys are great for taking the time to help out people..i really appreciate it!!!!!!!!
im going to go the 308 crank way cause of the balancing thing..($),so ill try sell/swap a 253 for one .. ps**** Byron which st
#13 Posted : Monday, 28 April 2008 7:10:55 AM(UTC)
NSW
#14 Posted : Monday, 28 April 2008 7:12:57 AM(UTC)
damn thats a long walk!!thanxz Byron
