HK350_2233 Offline
#1 Posted : Tuesday, 29 April 2008 5:43:11 AM(UTC)
HK350_2233
Hi, can someone help with what all the numbers mean?
Body HK80569-51078M
Trim 1172-14U
Paint 568-10845
Inset blank
Top blank
80569KJ163107
Do any of the numbers tell the Original motor and trans?
#2 Posted : Tuesday, 29 April 2008 7:41:42 AM(UTC)
HK80569-51078M
HK = HK
8 = Holden
05 = Premier
69 = sedan
51078 (sequential HK body number for Dandenong)
M = Dandenong, Melbourne
1172 = Ermine White paint
14U = Blue interior trim
568 = Solid colour
10845 = Dulon code for Ermine White.
8 =
HZ-GED Offline
#3 Posted : Tuesday, 29 April 2008 3:25:32 PM(UTC)
HZ-GED
Thanbks byron, thats the same info I was after. So where is the speedo cable position for the V8 model in comparison to the 6? Did the LSD Diff come optioned with the 6?
Your depth of knowlege still astounds me!
Thanks again;
Geoff
#4 Posted : Tuesday, 29 April 2008 4:13:23 PM(UTC)
I think the LSD would have been an option, the HR had an optional LSD.
#5 Posted : Tuesday, 29 April 2008 4:15:58 PM(UTC)
In HK V8 is towards centre of firewall. 6cyl is under the brake booster. V8 has both holes with the 6cyl one having a speedo cable grommet in it.
LSD was optional for 6cyl, standard in V8 pre July '68 and also from memory normally fitted to V8 post July
#6 Posted : Tuesday, 29 April 2008 4:15:58 PM(UTC)
LSD was optional for 6cyl, standard in V8 pre July 68 and also from memory normally fitted to V8 post July 6
#7 Posted : Thursday, 31 July 2008 4:48:39 AM(UTC)
I have unusual numbers in my id tag on my HR Holden. Can any tell me why and what they mean?
Body HR235A R-44019
Trim 585-F52
Paint 568-9562
Inset 122
Top Dblackvinyl
#8 Posted : Thursday, 31 July 2008 6:00:49 AM(UTC)
Grecian white with unknown insert Premier sedan with black vinyl roof and Black interior.
Not a bad combo.
A = Adelaide
R = Right hand drive
44019 = 44019th HR Prem from Adlaide
Warren
#9 Posted : Thursday, 31 July 2008 3:53:37 PM(UTC)
A is auto, what was I thinking?
Warren
#10 Posted : Saturday, 2 August 2008 4:32:28 AM(UTC)
hey guys how do i tell if my diff is lsd or not i have hk 6 cyl
peterwmh Offline
#11 Posted : Tuesday, 5 August 2008 1:06:33 AM(UTC)
peterwmh
Ryan, the A means auto and the R means righthand drive, I had a M R code on mine, it was factory 3 speed manual. The stamping on the firewall (behind the engine) tells you the plant it was built at should be something like HR12345M for a Melbourne buit c
#12 Posted : Tuesday, 5 August 2008 1:55:15 AM(UTC)
Peter, I think MR means Melbourne / RH drive, as I have early VB tags with BR on them - Acacia Ridge (Brisbane) assembled.
A lot of people aim to achieve nothing in lif
#13 Posted : Tuesday, 5 August 2008 2:26:15 AM(UTC)
Mick, A=Auto, M=Manual on HR. This continued on in HK in Brisbane only from memory.
