musksell Offline
#1 Posted : Friday, 2 May 2008 7:09:08 AM(UTC)
musksell
Talking to this bloke last night who was a mechanic for 15 yrs some years ago, he reckons for every holden v8 with a cracked head there would be at least 10 chevs, due a bit to there cooling problems which aren't helped by the water going around block before head.
Also they snap oil pump drive shafts, which in a lot of cases you have to pull engine out.....true or false...?
#2 Posted : Friday, 2 May 2008 8:38:55 AM(UTC)
Was thanked: 613 time(s) in 580 post(s)
Chevs crack heads due to flame hardened seats and also Americans not looking after them ie not changing the oil or water. Yes to replace an oil pump in a Chev you have to remove the engine.
If we
bundybluedog Offline
#3 Posted : Friday, 2 May 2008 10:31:29 AM(UTC)
bundybluedog
could the fact that it gets to -20c in america and -60c in canada make them crack?
musksell Offline
#4 Posted : Friday, 2 May 2008 4:52:30 PM(UTC)
musksell
it was in Australia
#5 Posted : Friday, 2 May 2008 5:39:09 PM(UTC)
Yes but most heads that come into Australia have run on cars in the USA.
adam PERTH Offline
#6 Posted : Friday, 2 May 2008 9:56:50 PM(UTC)
adam PERTH
yer, dont buy cast iron chev heads unless they are crack tested.
1 holden:10 chev, he wouldnt be far off.
Thats why in Nth ameerica they have heated welsh plugs that plug into the powerpoint.
Edited by user Friday, 2 May 2008 11:15:21 PM(UTC)  | Reason: Not specified
adam PERTH Offline
#7 Posted : Friday, 2 May 2008 9:56:50 PM(UTC)
adam PERTH
yer, don't buy cast iron chev heads unless they are crack tested.
1 holden:10 chev, he wouldn't be far off.
#8 Posted : Friday, 2 May 2008 10:49:52 PM(UTC)
bundybluedog
i lived in canada for 12 months there block heaters i would say less them 50% of people use them, i had a few cars and never had one even when it was -38c.
Sandman Offline
#9 Posted : Saturday, 3 May 2008 3:26:01 AM(UTC)
Sandman
Its pretty hard to say chevs are prone to cracking heads.
There are numerous different head castings, majority of which are pretty good.
Ive run chevs and been working on them for past 30 years and only had 1 set of heads crack.
These were early 292 c
Sandman Offline
#10 Posted : Saturday, 3 May 2008 3:26:01 AM(UTC)
Sandman
It's pretty hard to say chevs are prone to cracking heads.
I've run chevs and been working on them for past 30 years and only had 1 set of heads crack.
