#1 Posted : Saturday, 3 May 2008 5:50:29 AM(UTC)
i want to get some main caps for a 308 from a stuffed motor
so as not to rape good rebuilder...call jim 0401 975 612
will trade if ive got something you need....must be in adelaide s.a
or cheap postage ...budget buiding......jim
#2 Posted : Saturday, 3 May 2008 7:47:15 PM(UTC)
Was thanked: 632 time(s) in 594 post(s)
Jim
253 with the same rear main seal will do also. But whatever caps you use will require an align hone.
#3 Posted : Saturday, 3 May 2008 8:00:21 PM(UTC)
Thanks Byron ...do you have any spare?neoprene seal i guess...1971...qt2
and did you get the pics of uknown van?....cheers jim
#4 Posted : Sunday, 4 May 2008 3:01:04 AM(UTC)
how many you need???????? just threw 8 253s, and around 13 308s still have access to them though
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
#5 Posted : Sunday, 4 May 2008 3:01:04 AM(UTC)
how many you need???????? just threw 8 253's, and around 13 308's still have access to them though
boom Offline
#6 Posted : Sunday, 4 May 2008 3:17:58 AM(UTC)
boom
you threw out the 308s? why?
In cubes we trust.
#7 Posted : Sunday, 4 May 2008 3:24:47 AM(UTC)
Luke from sa has got some coming for me ..thanxz alot i will be after more stuff soon ...(budget build 308)ps.....dont throw away 308s..or better still throw them my way.....cheers jim
#8 Posted : Sunday, 4 May 2008 4:03:45 AM(UTC)
308s shouldnt be too hard to find. There are heaps of V8 VN-VT getting wrecked with worn out engines. A short should only be $500.
If we all had the same (good) taste, who would buy all the Fords
#9 Posted : Sunday, 4 May 2008 4:03:45 AM(UTC)
308's shouldn't be too hard to find. There are heaps of V8 VN-VT getting wrecked with worn out engines. A short should only be $500.
#10 Posted : Sunday, 4 May 2008 5:56:36 AM(UTC)
Thanks Byron...ive got a 1973 block 308 standard bore qt2***but it had no caps.
luke has got some for me , ive got a crank coming but the crank might be a rope seal ? dont know yet...just getting a bit from here an there before taking it to the machine s
#11 Posted : Sunday, 4 May 2008 6:13:58 AM(UTC)
a few cracked, 3 or 4 didnt sonic up nice on the thrust sides, some where up 60", courtesy of RPM engines, 1 had thrown a rod, all no good, and luckly i think,only 2-3 where tri-pattern, the rest Turbo pattern
"ANYONE C
This page was generated in 0.065 seconds.
