253tonner Offline
#1 Posted : Monday, 5 May 2008 4:52:46 AM(UTC)
253tonner
if putting 253 crank in 308 block can it be done
i do know one is myrofoan seal and one is rope seal
so can it be done
thanks
old holden rule
v8 are the go who
give's sh## about
fuel
#2 Posted : Monday, 5 May 2008 5:59:54 AM(UTC)
Was thanked: 593 time(s) in 561 post(s)
All 253/308 pre about 1972 are neoprene rear seal. After that they are rope.
253 and 304 and 308 cranks are different. The 5 litre cranks have heavier counterweights than the 253. The 304 and 308 cranks have different strokes (only just).
____________
253tonner Offline
#3 Posted : Monday, 5 May 2008 8:12:32 AM(UTC)
253tonner
253 and 3
old holden rule
v8 are the go who
give's sh## about
fuel
antoni Offline
#4 Posted : Monday, 5 May 2008 8:59:53 AM(UTC)
antoni
Hi 253 crank would be to light, cost to much to rebalance the crank to suit the 308 pistions.
308 cranks are geting cheaper, need one do it for $35.00
304 for $45.00 0407 56 53 28
ps vic west side . melton.
#5 Posted : Monday, 5 May 2008 5:05:04 PM(UTC)
As Antoni says, the weight is the difference. Stroke is the same except 304 is slightly less.
boom Offline
#6 Posted : Tuesday, 6 May 2008 7:59:22 AM(UTC)
boom
but the smaller stroke in turn gives a higher compression height due to same rods.
0.02" difference between pistons.
In cubes we trust.
mrhqute Offline
#7 Posted : Tuesday, 6 May 2008 9:02:36 AM(UTC)
mrhqute
surely a smaller stroke must give a lesser comp height when using same rods and pistons.
#8 Posted : Tuesday, 6 May 2008 6:22:56 PM(UTC)
304 uses a different piston to 308 due to the different stroke. 308 has a compression height of 1.69", and 304 of 1.71".
Boom, yes you got it the wrong way around.
If we all had the same (good)
Edited by user Wednesday, 7 May 2008 3:11:14 AM(UTC)  | Reason: Not specified
boom Offline
#9 Posted : Wednesday, 7 May 2008 2:33:36 AM(UTC)
boom
i dont think i did. i said the smaller stroke gives a higher compression height.
In cubes we trust.
#10 Posted : Wednesday, 7 May 2008 3:15:52 AM(UTC)
I see what you mean now. I think mrhqute and myself read your post as "308 pistons in a 304 push the pistons up the bore", whereas the truth is the opposite. You said the same thing as me but it was confusing.
boom Offline
#11 Posted : Wednesday, 7 May 2008 3:56:40 AM(UTC)
boom
ok my apologies. i see my blunder now!
In cubes we trust.
Guest (6)
