#1 Posted : Monday, 5 May 2008 7:59:29 AM(UTC)
I have a Holden HJ Monaro and it is fitted with standard engine electical system comprising of a points Distributor. During regular maintennace I noticed the writing on the back of the Coil, which is a factory silver coil, it writes "Use With Risisiter". I don't see a resister anywhere on the vehicle. My question is is there a factory fitted resister anywhere on the vehicle? If so where? If it is not fitted with one will this cause damage to my points etc because I think it has a sight electrical problem right at the moment!. Any help is most appreciated.
mrhqute Offline
#2 Posted : Monday, 5 May 2008 8:28:57 AM(UTC)
mrhqute
The resistor is built into the loom. Actually its a special wire, called resistance wiring.
mrhqute Offline
#3 Posted : Monday, 5 May 2008 8:28:57 AM(UTC)
mrhqute
The resistor is built into the loom. Actually it's a special wire, called resistance wiring.
#4 Posted : Monday, 5 May 2008 9:00:29 AM(UTC)
I would never have known. So this risister wire is it behind the firewall i.e in the cabin or in the engine bay? and what colour is it so I can confirm it has not been tampered with?
Appeciate the advice.
antoni Offline
#5 Posted : Monday, 5 May 2008 9:27:56 AM(UTC)
antoni
Hi it is the wire that it going to the + side of the coil .
that is the risister wire .
8 volts when runing 12 volts when starting ( 10 to 12 volts ).
Tony
JBM Offline
#6 Posted : Monday, 5 May 2008 4:21:37 PM(UTC)
JBM
mmazz30 Offline
#7 Posted : Tuesday, 6 May 2008 3:02:46 AM(UTC)
mmazz30
I thought it was the pink wire from the ignition switch to the
firewall plug on the inside.
From the out side plug it is a normal wire to the +ve side of the coil.
I could be wrong.
Cheers...mario
mrhqute Offline
#8 Posted : Tuesday, 6 May 2008 8:57:53 AM(UTC)
mrhqute
mmazz30 would have to be right, as the coil needs full voltage while cranking, and reduced voltage when running. So it has to be associated with the ign switch.
