#1 Posted : Thursday, 8 May 2008 6:49:07 PM(UTC)
Hi there,
I am hoping someone can help.
My Trimatic transmission in my ute (253)appears to be leaking large amounts of oil from the hole in the bell housing cover.
I would guess it has leaked about 1.5 litres of oil.
I refilled it, drove it, then when parked it leaked again.
Any advice very welcome.
thanks
#2 Posted : Thursday, 8 May 2008 11:10:19 PM(UTC)
I would say your torque converter seal is gone. Unfortunately its a transmission or engine out job to fix.
If at first you dont succeed then skydi
#3 Posted : Thursday, 8 May 2008 11:10:19 PM(UTC)
I would say your torque converter seal is gone. Unfortunately it's a transmission or engine out job to fix.
If at first you don't succeed then sky
#4 Posted : Friday, 9 May 2008 10:16:38 AM(UTC)
Is it red oil or black oil? if its red its transmission, if not its the engine rear seal. both mean the removal of the engine or transmission. personally I would remove them both together. easier to work on then. also don't forget to do the rear welsh plu
#5 Posted : Friday, 9 May 2008 10:16:38 AM(UTC)
Is it red oil or black oil? if its red its transmission, if not its the engine rear seal. both mean the removal of the engine or transmission. personally I would remove them both together. easier to work on then. also dont forget to do the rear welsh plug
#6 Posted : Saturday, 10 May 2008 12:10:47 AM(UTC)
Thank you all for your advice.
Dave
