HQforme Offline
#1 Posted : Friday, 9 May 2008 11:02:04 AM(UTC)
HQforme
So, on my warm 202 i've got a single 2inch strommy. Rebuild kit through it. Motor's brand new. Reconditioned dizzy, new points, cap, leads, plugs. Coil is stock.
Trouble is, i play and set the thing, timing, idle, mixture, and get it purring, idle and at revs...but then i turn the car off, back on shortly later, still nice and warm, and she's spluttery, won't idle at all without choke aiding it. But seems ok at revs.
Sometimes this even happens if i've got it all set, blip the throttle and it settles back into this gruff, crap idle.
I've checked all wiring, even eliminating my tacho from the circuit. Makes no difference.
Has to be carby or fuel right...any ideas?
Also, only once, whilst out driving, the car just stopped at 3500 rpm and wouldn't go higher. At all. Backed off, got on it around the next corner and she swings smoothly past.
I'm baffled, so i've come to my happy place. Hope you can help :-)
"Silly modern cars"
#2 Posted : Friday, 9 May 2008 4:23:10 PM(UTC)
on a `warm` 202 I would run a twin barrel stromberg as per 186S, I also would use electronic ignition from a blue 202 for better consistant spark.
Is the dizzy sercured tight to the motor after adjusting, if not it can move around upsetting the timing,
HQforme Offline
#3 Posted : Friday, 9 May 2008 9:48:40 PM(UTC)
HQforme
As luck would have it, ive got an X2 manifold and twin carbs. Just rebuilding the carbs and making linkages at the moment :-)
Motors 40thou over, ported head, larger valves, extractors.
Right now i just want it running nicely until i get the twins u
"Silly modern cars"
HQforme Offline
#4 Posted : Friday, 9 May 2008 9:48:40 PM(UTC)
HQforme
As luck would have it, i've got an X2 manifold and twin carbs. Just rebuilding the carbs and making linkages at the moment :-)
Motor's 40thou over, ported head, larger valves, extractors.
"Silly modern cars"
JBM Offline
#5 Posted : Friday, 9 May 2008 9:53:23 PM(UTC)
JBM
Vacuum leaks? Is the condensor new as well? Any new paint under an earth wire?
James
#6 Posted : Saturday, 10 May 2008 1:55:06 AM(UTC)
check vacuum advance unit on the side of the dizzy for leaks remove one end of the plastic tube and suck on it to check
#7 Posted : Saturday, 10 May 2008 8:31:28 AM(UTC)
you might have an air leak somewhere causing it to run lean. have you checked for slop in the throttle shaft etc? spray some wd 40 around the shafts with the engine running see if it makes a difference.
#8 Posted : Saturday, 10 May 2008 8:32:56 AM(UTC)
also check the vacuum advance on the distributor is working it could have a leak affecting the carby.
