#1 Posted : Monday, 12 May 2008 9:40:50 AM(UTC)
gday i got a 351 clevo and looking at a tunnel ram and the ones ive seen are 302 or windor and just wondering whats the difference or if they all the same
or any ideas
[x/d]
#2 Posted : Monday, 12 May 2008 11:19:00 PM(UTC)
You will definetly need Cleveland tunnel ram set up. When looking, remember that all windsor manifolds (and the so-called 400m engine may be referred to as a clevo but has a different manifold again?) have the thermostat housing at the front of them, the
#3 Posted : Tuesday, 13 May 2008 8:17:49 AM(UTC)
This not a bad buy. A little over carbed for I assume what you want but good price. possibly a little restriction unless he ran the putty up the runners all the way and not just at the port ends... what a **** load of work to do to a 4v ram.?? weird as bu
#4 Posted : Wednesday, 14 May 2008 7:36:53 AM(UTC)
I stuffed up and bought one of the 50,000 hei dizzy with coil in cap before buying a 4v ram for my clevo. Oh oh him no fit ,anyway I have the 4v ram going on to 2v heads will i have problems?
#5 Posted : Wednesday, 14 May 2008 5:16:42 PM(UTC)
hey Landau, I really think u should look at buying a 2v ram, think u will find the 4v runners will be way too big for the old heads mate. unless ya start port matching, and I doubt there is enuf meat on the heads to do a good job ?
#6 Posted : Friday, 23 May 2008 12:01:54 PM(UTC)
gday its me again just wonderin a guy told me a twin carb tunnel ram for the clevo will be to high out of the bonnet to be street legal just wondering if this is true or not and if any one had the hight law (how high its allowed to be cheers
[x/d]
Docktor Offline
#7 Posted : Friday, 23 May 2008 7:01:23 PM(UTC)
Docktor
No idea for tassie mate, but victoria is from memory 25mm or half a tennis ball on a forward facing scoop. (except factory scoops). i can cover my rams with a xc cobra scoop.... just which makes it legal to look at. only ran the scoop to pass rwc and took
landau37 Offline
#8 Posted : Saturday, 24 May 2008 5:59:21 AM(UTC)
landau37
My mate has a blue xd with a xf front with a big block, tunnelramed ex show car , was in street fords ( hes selling it by the way) and im sure it was street legal in nsw with out scoope.
c.rice
c.rice
#9 Posted : Monday, 16 June 2008 12:26:13 AM(UTC)
Im looking at buying a Tunnel ram kit for my 302 cleveland. Which is stock by the way. Am I wasteing my time?
I was woundering if anyone had a good set up for this (what carbs to use? What tunnel ram etc?). I was told to get some 390 hollys.
Not sure bo
basketcasebear Offline
#10 Posted : Monday, 16 June 2008 4:53:54 AM(UTC)
basketcasebear
eerrhh, dumb question probably,,,but what exactly does a tunnel ram do??
eg,,is it a fan,,or superchager thingy, or just uses air pushing thru front opening?
thanks
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that ne
DOH!!!
#11 Posted : Tuesday, 17 June 2008 7:54:44 AM(UTC)
No BCB, there is no trickery to a Tunnelram, just those long runners, cooler air from your air cleaner/s sticking out your bonnet. As for a tunnel ram and twin carbs on a stock 302, that would be a definite overkill.
#12 Posted : Wednesday, 18 June 2008 11:57:09 PM(UTC)
Thanks for the reply 302Superbird.
If I was to put a better cam in would I then beable to run a tunnel ram no problems..?
If so what cam should I run anyone know? Or has anyone played around with a 302clevo with tunnel ram before??
I am not going for b
This page was generated in 0.080 seconds.
