HarryO Offline
#1 Posted : Monday, 12 May 2008 10:15:10 PM(UTC)
HarryO
Hi guys. Quick one....
The gear from my distributor has disappeared into the sump. I am about to head off & purchase a replacement gear. It is a Bosch HEI from a Commodore VH 3.3 (9230 064 700) fitted to a red 186. Are the gear patterns identical as not sure whether to specify the gear for a 186 or 202.
Thanks for any help.
#2 Posted : Monday, 12 May 2008 10:23:15 PM(UTC)
same tooth pattern. I think all HEI gears are steel. other gears were made of plastic or steel. May be able to get bronze gears?
HarryO Offline
#3 Posted : Monday, 12 May 2008 10:33:07 PM(UTC)
HarryO
Thanks heaps! Autobarn have quoted $25 so I hope its made of gold! Cheers :)
HarryO Offline
#4 Posted : Monday, 12 May 2008 10:33:07 PM(UTC)
HarryO
Thanks heaps! Autobarn have quoted $25 so I hope it's made of gold! Cheers :)
#5 Posted : Monday, 12 May 2008 10:55:54 PM(UTC)
check if the roll pin is still there. If it's there you probably had a plastic gear that has broken off. If not there make sure you get one with your new gear
#6 Posted : Monday, 12 May 2008 10:55:54 PM(UTC)
check if the roll pin is still there. If its there you probably had a plastic gear that has broken off. If not there make sure you get one with your new gear
HarryO Offline
#7 Posted : Tuesday, 13 May 2008 5:57:45 AM(UTC)
HarryO
Pin was intact, nothing else. Replacement drive came with new pin. Working a treat. Thanks again!
boom Offline
#8 Posted : Tuesday, 13 May 2008 7:31:12 AM(UTC)
boom
$25 is cheap. wait till you start needing hardened gears for roller cams. sheesh!
In cubes we trust.
Guest (5)
