#1 Posted : Wednesday, 14 May 2008 3:57:42 AM(UTC)
i want to start up my 308 that ive had sitting in the garage for the last year without being touched. i know i should have done a few things before i put it away and turned it over occasionally but i never thought it would be sitting there for that long. my question is should i do anything before i crank it over? i assume all the oil will have run out of the bearings and lifters etc. thanks for any advice.
bundybluedog Offline
#2 Posted : Wednesday, 14 May 2008 10:25:43 AM(UTC)
bundybluedog
take the spark plugs out so there is no compression, disconect the coil so you dont go arcing out everywere and crank her over but dont crank for anymore then about 15-20 seconds at a time or you may fry your starter.
#3 Posted : Wednesday, 14 May 2008 9:04:58 PM(UTC)
Hi There,
I have two motors, a 253 and a 308 that I have had sitting in the shed for periods of up to 18 months and when I have gone to start both of them they have both had no oil pressure.
I have had to pull off the oil pump, pack it with petroleum je
adam PERTH Offline
#4 Posted : Wednesday, 14 May 2008 9:23:39 PM(UTC)
adam PERTH
i wouldnt worry too much.
12 months isnt too long.
byt the time your fuel gets there, you should have oil pressure.
adam PERTH Offline
#5 Posted : Wednesday, 14 May 2008 9:23:39 PM(UTC)
adam PERTH
i wouldn't worry too much.
12 months isn't too long.
#6 Posted : Friday, 16 May 2008 7:37:46 AM(UTC)
rev the crap outta it
#7 Posted : Friday, 16 May 2008 8:18:16 PM(UTC)
Depending on the condition of the oil before it was last started, the crank some times has rust starting on it, and it may of had a valve open in all this time to. i think, if before you are going to have a motor sit for a long time change the oil before
