gmholdman Offline
#1 Posted : Thursday, 15 May 2008 12:29:27 AM(UTC)
gmholdman
Will a eh 6 gear box(on the column shift) go into a hk 6 and still retain the column shift. Any mods needed?? AL.
Edited by user Friday, 16 May 2008 9:32:04 PM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 15 May 2008 12:54:22 AM(UTC)
depends whether the EH is an orig crash box and the HK is a crash. If one is a synchro you have to change bits
gmholdman Offline
#3 Posted : Thursday, 15 May 2008 3:50:24 AM(UTC)
gmholdman
3speeds, thanks for the reply, the eh has a synchro going into a hk(both column shift) May have to change linkages???? al.
gmholdman Offline
#4 Posted : Friday, 16 May 2008 9:28:40 PM(UTC)
gmholdman
Can anyone give me some feedback???? AL.
#5 Posted : Friday, 16 May 2008 9:48:42 PM(UTC)
Youll need column linkages off a HK originally fitted with a synchro box, or I believe any HT or HG with column 3 speed (these were all synchro boxes, but synchro was optional on HK). If the HK is currently a crash box it will by hydraulic clutch, so youl
#6 Posted : Friday, 16 May 2008 9:48:42 PM(UTC)
You'll need column linkages off a HK originally fitted with a synchro box, or I believe any HT or HG with column 3 speed (these were all synchro boxes, but synchro was optional on HK). If the HK is currently a crash box it will by hydraulic clutch, so you
This page was generated in 0.111 seconds.
