HQforme Offline
#1 Posted : Saturday, 17 May 2008 12:38:43 AM(UTC)
HQforme
I've got an X2 manifold that i'd like to put on my red 202. Motor's 40thou over, flat tops, ported head, bigger valves, mild cam, extractors. I wish to run twin Stromberg's. Currently the stock manifold with 2inch strommy runs the standard coil and points dizzy.
I'm assuming i'll need an upgrade, would the electronic setup from a later 202 fit and do the job?
Also, on the manifold there are two ports, one each end. Not for the pcv valve. What are they? I plan to just blank them off.
Any advice is appreciated :-)
"Silly modern cars"
special-k Offline
#2 Posted : Saturday, 17 May 2008 1:15:23 AM(UTC)
special-k
I would go with the commodore electronic system as I have used this myself with the same mods as you are using except I was running triples.Its gives good spark and is good value for money.As for the two ports without seeing the manifold I would say they
80737k Offline
#3 Posted : Saturday, 17 May 2008 1:20:29 AM(UTC)
80737k
Upgrading to HEI (later 202 electronic ignition) is always a good idea and quite easy to do. Check the links i've provided to show you the way.
http://holdenpaedia.oldh....com/Electronic_Ignition
http://holdenpaedia.oldh...en.com/HEI_Conversion_Wi
Fossil fuels are YUMMY !
80737k Offline
#4 Posted : Saturday, 17 May 2008 1:20:29 AM(UTC)
80737k
Upgrading to HEI (later 202 electronic ignition) is always a good idea and quite easy to do. Check the links ive provided to show you the way.
http://holdenpaedia.oldh...n.com/HEI_Conversion_Wir
boom Offline
#5 Posted : Saturday, 17 May 2008 2:38:02 AM(UTC)
boom
you could always use the optical dizzy off a carby VK, and buy a jaycar EST system to replace the old ****ty one. will give you complete adjustability of your ignition system.
In cubes we trust.
tripple webers Offline
#6 Posted : Saturday, 17 May 2008 4:11:57 AM(UTC)
tripple webers
What ever distributor you use (preferably electronic) take it to an IGNITION SPECIALIST and get it graphed to suit the modifications you have done, make sure you have your cam timing details, otherwise you will never achieve full potential out of your eng
#7 Posted : Saturday, 17 May 2008 8:14:54 AM(UTC)
HQforme Offline
#8 Posted : Sunday, 18 May 2008 4:18:55 AM(UTC)
HQforme
Cheers guys, some sound advice.
Boom, i think i know what you mean with optical triggering, but thought it was only on late model cars?
"Silly modern cars"
Guest (5)
