BROUGHAM DIFF'S did the HK 307 v8 come std with 3.36 ratio and was it a salisbury. I think the HT-G 308 V8 broughams came std 2.78 ratio only? with the salisbury.
All Broughams should be 2.78 or 3.08 banjo. Normally LSD in my experience. The lowest ratio Salisbury available was a 3.08
My HG Brougham is 3.08 LSD.
Go the Dragons! |
Go the Dragons! |
So we have broughams with banjo 2.78 std and if you ordered a 3.08 you may get a banjo or salisbury. a old dude i know bought the HK 307 then the HT 308 and the HG brougham all brand new. and is saying the HK 307 performed the best, and recons the 308s we
So we have broughams with banjo 2.78 std and if you ordered a 3.08 you may get a banjo or salisbury. a old dude i know bought the HK 307 then the HT 308 and the HG brougham all brand new. and is saying the HK 307 performed the best, and recons the 308's w
My HT Brougham has the 2.78 Banjo (I've never checked if its an LSD, I just assumed they'd all be single wheelers). The high ratio and extra wieght certainly does make it feel lazy, even with a more open exhaust. In my opinion this is what makes them so n
My HT Brougham has the 2.78 Banjo (Ive never checked if its an LSD, I just assumed theyd all be single wheelers). The high ratio and extra wieght certainly does make it feel lazy, even with a more open exhaust. In my opinion this is what makes them so nic
81837 have you got a trimatic with it. I had a HG, std 253 with 2 1/2 exhaust, trimatic auto with 2.78 diff. and a mate had a std XC 351 auto with a 2.75 diff twin exhaust, they were allways neck & neck, in a drag. i put a 3.55 ratio in the HG and got bl
Its a 308 powerglide rosenberg, 2.5" exhaust the only mod. It would not pull the skin off a rice pudding but is a pleasure to cruise in.
Dr Terry will probably confirm the diff thing, but I am almost certain tha all Broughams were banjos. Either 2.78 or possibly 3.08. Most will be LSD.
Brougham engine boxes go like this: HK - 307 powerglide. HT - 308 powerglide. HG - 308 trimatic. (I |
Bryon, My friends father did have a HG Brougham with a 253 from new..i can reecall my dad bagging him for buying a small V8
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
HK had 307/powerglide/2.78 LSD HT 308/powerglide/2.78 HG 308/trimatic/2.78
Not available with 253, although HK export was to get 253 low comp engine before it was droped.
I always found it interesting that a 307 got LSD as standard but 308 did not
It may have just been a follow on from pre Monaro/Brougham where all V8's were 2.78 LSD banjo??
Thanks for clearing up the Brougham diff thing Warren. It is not info that is easy to obtain. It must be V8 Premiers that had optional 3.08 in a V8 banjo??
It may have just been a follow on from pre Monaro/Brougham where all V8s were 2.78 LSD banjo??
Yes 3.08 banjo for everything but Brougham and GTS.
Warren
quote: Originally posted by rosenberg
So we have broughams with banjo 2.78 std and if you ordered a 3.08 you may get a banjo o |
