308hjute Offline
#1 Posted : Sunday, 18 May 2008 5:25:11 PM(UTC)
308hjute
Are there diffences between the actual control arms between RTS and non-RTS front ends? Or is the difference only in the mounting points?
Kev
HZute-efi-VS5L Offline
#2 Posted : Sunday, 18 May 2008 9:28:59 PM(UTC)
HZute-efi-VS5L
i believe its just the mounts kev. and maybe the top control arm piviot bolt.
jason
www.stickthisdecals.com.au
#3 Posted : Sunday, 18 May 2008 10:21:28 PM(UTC)
what is rts and non rts
#4 Posted : Sunday, 18 May 2008 11:00:02 PM(UTC)
Radial Tuned Suspension Dan. fitted to the HZ-WB range.
i have never put the 2 control arms together. but i heard that the lower arms on a HZ WB have a brace to take the weight of the RTS as the HQ HJ doesnt have the brace. maybe Byron or Terry could he
308hjute Offline
#5 Posted : Monday, 19 May 2008 4:31:45 AM(UTC)
308hjute
Jason,
Cheers, I had a look on the online shop (Rares) and they list only one part number for the whole series.
Kev
#6 Posted : Monday, 19 May 2008 6:37:40 PM(UTC)
HQ-WB control arms are the same. Only difference is at some stage the bottom shock hole was cut larger to allow bigger shocks.
The difference is in the RTS upper control arm mounts on the chassis rails. This started mid HX.
___________________________
