Joined: 2/03/2005(UTC) Posts: 117  ![Australia Australia]()
Are there diffences between the actual control arms between RTS and non-RTS front ends? Or is the difference only in the mounting points?
Kev
i believe its just the mounts kev. and maybe the top control arm piviot bolt.
cheers jason |
Radial Tuned Suspension Dan. fitted to the HZ-WB range. i have never put the 2 control arms together. but i heard that the lower arms on a HZ WB have a brace to take the weight of the RTS as the HQ HJ doesnt have the brace. maybe Byron or Terry could he
Jason,
Cheers, I had a look on the online shop (Rares) and they list only one part number for the whole series.
Kev
HQ-WB control arms are the same. Only difference is at some stage the bottom shock hole was cut larger to allow bigger shocks. The difference is in the RTS upper control arm mounts on the chassis rails. This started mid HX.
___________________________ |
