basketcasebear Offline
#1 Posted : Monday, 26 May 2008 5:16:06 AM(UTC)
basketcasebear
hey yall,
what is the thickness of car bodies, and can i weld gal to the normal car metal?
thanks already
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
Fred Offline
#2 Posted : Monday, 26 May 2008 5:49:07 AM(UTC)
Fred
I always use a gal type metal for welding in rust repairs.
#3 Posted : Monday, 26 May 2008 5:49:40 AM(UTC)
2-3mm and you can weld gal to car sheet metal. Gal is just a coating Strip the gal off where you want to weld with a sander for a better weld.
#4 Posted : Monday, 26 May 2008 6:01:49 AM(UTC)
as boilmaker stated, simply gring/sand/file roughly 3mm from the edge of the gal panel to avoid the gal coating contaminating the weld, also a cars metal thickness varies from chassis to panels & what car make/model you are welding the section into, it ca
#5 Posted : Monday, 26 May 2008 8:22:00 AM(UTC)
basketcasebear
thanks men,
it is for the sections i have to get bent up for around the roof opening in the campervan.
it certainly isnt 3mm thick, but looks about .9>1.2mm
it seems like a very soft metal, not like say zincalume,?
I will get 1.2mm, maybe normal m
DOH!!!
#6 Posted : Tuesday, 27 May 2008 4:20:27 AM(UTC)
I sometimes have to weld small repairs on .75mm-1.0mm with a mig on new car panels settings are coarse 1 .fine 2 or 3. wire speed 4. this is on a CIG mig 250 unit. this combo usually does the job without blowing through, takes a lot of practise and patien
#7 Posted : Tuesday, 27 May 2008 4:52:57 AM(UTC)
basketcasebear
hey cloudy,
thanks for that, i only have a mig 150, and it is very tricky,,
i tried to day to get sheetmetal workers to give me a price for the 4 pieces I need,, to no avail,
so i am going to get some gal C section purlins, and manufacturer them mysel
DOH!!!
#8 Posted : Tuesday, 27 May 2008 5:59:29 AM(UTC)
caution welding galv , it gives off poisonous fumes, when my father was a welder they used to make them drink milk when welding galv it must help with the poison you inhale.
#9 Posted : Tuesday, 27 May 2008 6:05:47 AM(UTC)
basketcasebear
aaarrrhhh! so thats what caused it!!
doh!!
ptpro
DOH!!!
camlj Offline
#10 Posted : Tuesday, 27 May 2008 7:45:52 AM(UTC)
camlj
yeh strip the gal back to stop it contaminating the weld. wear a mask though. its dangerous sh!t.
#11 Posted : Tuesday, 27 May 2008 8:42:26 AM(UTC)
#12 Posted : Wednesday, 28 May 2008 3:44:22 AM(UTC)
basketcasebear
thanks monaro202
i am getting normal painted steel purlins, so wont be gal,
but i was not aware of how dangerus it was, so in future will be more careful, dont want to carc it yet, got to win the campervan race around the mount yet!!
ptpro
DOH!!!
This page was generated in 0.083 seconds.
