tenticles Offline
#1 Posted : Monday, 26 May 2008 5:56:46 AM(UTC)
tenticles
hi, still going through the process of deciding whether to go 350 chev or 355 holden
and 1 of the things i'm wondering is the hp demands of the turbo 350, 400 and the trimatic
i think i remember seeing 18 hp for the trimatic and about 40 hp for the turbo 400, but not sure
yes sonny, it's an HQ ute
#2 Posted : Monday, 26 May 2008 6:30:34 AM(UTC)
go 4 speed auto, early VN cable kickdown type..you wont look back
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
#3 Posted : Monday, 26 May 2008 7:07:32 AM(UTC)
Refresh my memory, what do you have now? Not just engine but radiator, exhaust, shifter etc?
tenticles Offline
#4 Posted : Monday, 26 May 2008 8:13:27 AM(UTC)
tenticles
hi byron
i have a dismantled 350 and all the parts to rebuild it, plus a turbo400, b&m shifter, 1 tonner large yoke diff, new hooker headers (not sure if theyll fit under the holden bonnet)
so ill need a radiator, rear gearbox crossmember ( or can i
tenticles Offline
#5 Posted : Monday, 26 May 2008 8:13:27 AM(UTC)
tenticles
hi byron
i have a dismantled 350 and all the parts to rebuild it, plus a turbo400, b&m shifter, 1 tonner large yoke diff, new hooker headers (not sure if they'll fit under the holden bonnet)
so i'll need a radiator, rear gearbox crossmember ( or can
#6 Posted : Monday, 26 May 2008 5:25:44 PM(UTC)
Whats in the car now though.
#7 Posted : Monday, 26 May 2008 5:25:44 PM(UTC)
What's in the car now though.
tenticles Offline
#8 Posted : Monday, 26 May 2008 5:59:42 PM(UTC)
tenticles
hi byron
stock (i think) hz 308 with rebuilt q jet, impco dual fuel, stock exhausts, new (holden) 3 core radiator, column shift stock trimatic (whiney 2nd) and 3.36 salisbury
yes sonny, its an HQ ute
tenticles Offline
#9 Posted : Monday, 26 May 2008 5:59:42 PM(UTC)
tenticles
hi byron
#10 Posted : Monday, 26 May 2008 6:18:11 PM(UTC)
I know you have all that other stuff but if it all needs rebuild Id consider selling it and rebuilding the 308 as a 350 (5.7) and building up the trimatic or replacing it with a rebuilt VK or VL box. The TH400 is a very durable box and I would keep it if
#11 Posted : Monday, 26 May 2008 6:18:11 PM(UTC)
I know you have all that other stuff but if it all needs rebuild I'd consider selling it and rebuilding the 308 as a 350 (5.7) and building up the trimatic or replacing it with a rebuilt VK or VL box. The TH400 is a very durable box and I would keep it if
tenticles Offline
#12 Posted : Monday, 26 May 2008 7:31:25 PM(UTC)
tenticles
t/y byron
i really like the idea of the 350 chev, but as you point out, too many things need converting
ill see what the universe sends my way ( meaning, ill prolly hold out for an hq 308 block for the conversion )
tenticles Offline
#13 Posted : Monday, 26 May 2008 7:31:25 PM(UTC)
tenticles
t/y byron
i'll see what the universe sends my way ( meaning, i'll prolly hold out for an hq 308 block for the conversion )
boom Offline
#14 Posted : Friday, 30 May 2008 6:53:41 AM(UTC)
boom
how much power do you want? the trimatic should be great unless you are going for a high horsepower bruiser.
In cubes we trust.
The Yeti Offline
#15 Posted : Friday, 30 May 2008 4:45:18 PM(UTC)
The Yeti
go the sbc the bang for buck in go fast gear cant be matched, the 400's ok but I would try for a kick down type 700 and a worked over 425impco takes care of the high fule costs
See The Yeti's Chev build at
http://www.ozrodders.com/board/viewtopic.php?
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
http://www.ozrodders.com...rd/viewtopic.php?t=17919
The Yeti Offline
#16 Posted : Friday, 30 May 2008 4:45:18 PM(UTC)
The Yeti
go the sbc the bang for buck in go fast gear cant be matched, the 400s ok but I would try for a kick down type 700 and a worked over 425impco takes care of the high fule costs
See The Yetis Chev build at
http://www.ozrodders.com/board/viewtopic.php?t=
This page was generated in 0.109 seconds.
