#1 Posted : Monday, 26 May 2008 6:38:53 PM(UTC)
I have a a WB one tonner with a 253 V8, wondering if anyone could give me some tips:
1. How do you remove the cable from the speedometer? Is the gauge and the cable one item and must disconnected from the gear box in order to remove? I had the dash apart but cant seem to get the cable out of the back of the gauge, concerned I might break the gauge applying to much force.
2. Does anyone have a copy of the wiring diagram for the WB? Or know where i can get a copy?
3. I am planning to take out the engine (first time) is there anything I should be aware of before I start?
4. Has anyone done an aftermarket setup on the dash i.e gauges, dash panel. Pics would be great to get some ideas flowing.
5. Does anyone know of a place in Victoria that could knock up a flat bed steel tray, I am after something simple with checker plate deck, intergrated tail lights, and removable sides.
Appreciate feedback
#2 Posted : Monday, 26 May 2008 8:09:52 PM(UTC)
The cable just pulls out of the guage. The cable has an integral plastic ring around it that you have to pull back to unlock it.
Buy a Gregory's manual. I think they only do a 6cyl but it's basically the same.
Make sure everything is disconnected be
#3 Posted : Monday, 26 May 2008 8:09:52 PM(UTC)
Buy a Gregorys manual. I think they only do a 6cyl but its basically the same.
Make sure everything is disconnected befo
mackv8 Offline
#4 Posted : Tuesday, 27 May 2008 3:49:10 AM(UTC)
mackv8
if you are in melbs west i may be able to help with the tray etc
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
