Joined: 28/05/2008(UTC) Posts: 6 ![Australia Australia]()
hey all. Does any one know if on theyre brockie theyre body number ( stamped on the front of the car ) matches the vin / chasis number on the silver tag on the right. The vc i am looking at buying has all the tag numbers matching but i am a bit worried about the body number not matching the number on the tag? Any ones input would be great. Cheers
If you are talking about the chassis number on the radiator support panel, than that should be the same as the chassis number on the ADR plate eg AVC12345M or whatever a VC chassis number looks like. Neither of these numbers lines up with the VIN number w |
If you can get hold of Commodorenut he is the man you need. Alternatively you may be able to get it verified at www.brockcommodores.com - his website.
Yeah on the car im looking at the chasis number doesnt match the adr plate, which leads me to believe that the car may be a rebirth. All the other tags line up to hdt and the car has the stearing wheel and the irmschers (minus caps ) flair kit 308 and 4
Ive sent you an email.
Email me back with its location - Im not far from HDT, and I often call in there too.
If it gets to HDT, or its within a reasonable distance of my regular travels (I cover a lot of ground with work) then Id be willing to tak |
I've sent you an email.
Email me back with it's location - I'm not far from HDT, and I often call in there too.
If it gets to HDT, or it's within a reasonable distance of my regular travels (I cover a lot of ground with work) then I'd be willing t |
Im in perth so yeah i mite as well be in another country. I have sent u an email. Hope fully thats eenough info. Cheers.
Ive replied back to the email. Its not looking good when the chassis number stamped on the shell pre-dates the chassis number on the compliance plate, and the approximate date of the GMH body plate, by some 2 months.
This is the perfect example of whe |
I've replied back to the email. It's not looking good when the chassis number stamped on the shell pre-dates the chassis number on the compliance plate, and the approximate date of the GMH body plate, by some 2 months.
This is the perfect example of w |
