brock0582 Offline
#1 Posted : Friday, 30 May 2008 8:58:09 AM(UTC)
brock0582
hey all. Does any one know if on theyre brockie theyre body number ( stamped on the front of the car ) matches the vin / chasis number on the silver tag on the right. The vc i am looking at buying has all the tag numbers matching but i am a bit worried about the body number not matching the number on the tag? Any ones input would be great.
#2 Posted : Friday, 30 May 2008 4:46:21 PM(UTC)
If you are talking about the chassis number on the radiator support panel, than that should be the same as the chassis number on the ADR plate eg AVC12345M or whatever a VC chassis number looks like. Neither of these numbers lines up with the VIN number w
hx-sandman Offline
#3 Posted : Friday, 30 May 2008 6:48:29 PM(UTC)
hx-sandman
If you can get hold of Commodorenut he is the man you need. Alternatively you may be able to get it verified at www.brockcommodores.com - his website.
brock0582 Offline
#4 Posted : Friday, 30 May 2008 7:08:22 PM(UTC)
brock0582
Yeah on the car im looking at the chasis number doesnt match the adr plate, which leads me to believe that the car may be a rebirth. All the other tags line up to hdt and the car has the stearing wheel and the irmschers (minus caps ) flair kit 308 and 4
#5 Posted : Friday, 30 May 2008 7:13:29 PM(UTC)
Ive sent you an email.
Email me back with its location - Im not far from HDT, and I often call in there too.
If it gets to HDT, or its within a reasonable distance of my regular travels (I cover a lot of ground with work) then Id be willing to tak
#6 Posted : Friday, 30 May 2008 7:13:29 PM(UTC)
I've sent you an email.
Email me back with it's location - I'm not far from HDT, and I often call in there too.
If it gets to HDT, or it's within a reasonable distance of my regular travels (I cover a lot of ground with work) then I'd be willing t
brock0582 Offline
#7 Posted : Friday, 30 May 2008 7:25:12 PM(UTC)
brock0582
Im in perth so yeah i mite as well be in another country. I have sent u an email. Hope fully thats eenough info. Cheers.
#8 Posted : Friday, 30 May 2008 8:30:48 PM(UTC)
Ive replied back to the email. Its not looking good when the chassis number stamped on the shell pre-dates the chassis number on the compliance plate, and the approximate date of the GMH body plate, by some 2 months.
This is the perfect example of whe
#9 Posted : Friday, 30 May 2008 8:30:48 PM(UTC)
I've replied back to the email. It's not looking good when the chassis number stamped on the shell pre-dates the chassis number on the compliance plate, and the approximate date of the GMH body plate, by some 2 months.
