Joined: 25/12/2006(UTC) Posts: 49  ![Australia Australia]() Location: In the shed Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Does anybody know how many HT 350 Automatic monaro's were built? I was also told the petrol tanks were smaller than the manuals? Is there any truth to this? Thanks Darcy
Last time I conversed with Ben Stewart on this he only had a handfull of HT/G 350 autos recorded. They are very rare today, and I don't think many were sold either. They only have a small tank. There are a few differences to go along with the 350 but in |
Last time I conversed with Ben Stewart on this he only had a handfull of HT/G 350 autos recorded. They are very rare today, and I dont think many were sold either. They only have a small tank. There are a few differences to go along with the 350 but in e |
Thanks for your reply! I have an original HT350 auto monaro but the tank is the bathurst size, could this be factory? And when you & others state small tank are you refering to the normal tank you would get in a 4 door or ? Thanks again D
The big tank has probably been added post factory. Send me a photo of the passenger's side wheel well area showing the filler neck and we'll see. Yes, small tank is the same as the rest BUT you'll need one out of a 5 litre car to get the hump in the front |
The big tank has probably been added post factory. Send me a photo of the passengers side wheel well area showing the filler neck and well see. Yes, small tank is the same as the rest BUT youll need one out of a 5 litre car to get the hump in the front of |
So Byron did the 308 ht-g prems have salisbury diffs fitted? Was there any other holden fitted with the early salisbury diff other than the hk-t-g monaros?-Garry
Yes. Plenty of 5 litre Premiers and Kingswoods got them.
I have a HK Prem wagon with a 307, four speed and 10 bolt. It has the bump in the trans tunnels and the boot. Yes I can vouch for prems getting 10 bolts.
Yes all KTG 307/308 manuals in Belmont, Kingswood, Monaro Monaro GTS and Premier got the 10 bolt, plus the 10 bolt came behind 307/308 Monaro GTS and optional on Belmont, Kingswood, Monaro and Premier with 307/308 and auto. These are quite rare though as
Werent Salisburys fitted to all cars fitted with a 5ltr or larger engine. Optional of smaller engined cars. Leroy |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
Werent Salisbury's fitted to all cars fitted with a 5ltr or larger engine. Optional of smaller engined cars. Leroy |
No. Warren is correct. Plus AFAIK they were optional only on V8s, not on 6cyl. Possibly not even optional on 253.
No. Warren is correct. Plus AFAIK they were optional only on V8's, not on 6cyl. Possibly not even optional on 253.
Joined: 1/03/2005(UTC) Posts: 241  ![Australia Australia]() Thanks: 3 times
I think we've had this conversation before..you might remember Byron i mentioned my brother had a sebring orange HT 81837 that was factory auto but had the big tank, 10 bolt diff and radius rods from factory as well. This was close to 20 years ago so i d Edited by user Saturday, 31 May 2008 4:39:43 AM(UTC)
| Reason: Not specified |
Jesse Jesse Jesse, you've not got a sense of humour! |
I think weve had this conversation before..you might remember Byron i mentioned my brother had a sebring orange HT 81837 that was factory auto but had the big tank, 10 bolt diff and radius rods from factory as well. This was close to 20 years ago so i do Edited by user Saturday, 31 May 2008 4:39:43 AM(UTC)
Thats very interesting! I have never checked the diff ratio , I just presumed it was 3.36 like most. Do the hk-g 10 bolts have the ratio stamped around the dust cover like the hq-wb v8 salisburys or is it a matter of removing the backing plate???
As the front floor would have to be modified to fit a saginaw, it is more likely your brother had a manual car with auto engine fitted, rather than an auto car with manual trans, manual tank and manual radius rods.
Especially when you consider how much
Warren are you saying ALL HT 350 Auto monaro's were built in qld? Thanks
Warren are you saying ALL HT 350 Auto monaros were built in qld? Thanks
