tenticles Offline
#1 Posted : Saturday, 31 May 2008 8:00:12 PM(UTC)
tenticles
QT 204811
this came out of a 1978 hz ute i wrecked and i was wondering how old it is. i don't think it was the engine originally fitted
many thanx once again, johnny
yes sonny, it's an HQ ute
#2 Posted : Saturday, 31 May 2008 8:38:17 PM(UTC)
Hi thanks for the offer, i would like to date your 308 but i need to know does she put out? And does the carpet match the drapes? Or no carpet? How old is she? Colour? Also some photos would help
Ta
tenticles Offline
#3 Posted : Saturday, 31 May 2008 8:43:55 PM(UTC)
tenticles
sorry, smooth stalker
but she wants to date someone with an IQ higher than their school leaving age
tenticles Offline
#4 Posted : Saturday, 31 May 2008 8:43:55 PM(UTC)
tenticles
yes sonny, its an HQ ute
Mr.Jones Offline
#5 Posted : Saturday, 31 May 2008 9:12:05 PM(UTC)
Mr.Jones
I have QD198791 as Aug 72 and QT207460 as Sept 72 should put you in the ball park can you get back to me with a date code, should be a month or 2 earlier as I go by the date on the ADR plate with my records
Leroy
Voltaire
tenticles Offline
#6 Posted : Saturday, 31 May 2008 9:25:55 PM(UTC)
tenticles
hi mr J
the hz ute has gone, it was a donor car for my hq
so, i don't have the ADR plate or
oopps, just found the receipt i gave the buyer
chassis no. BHZ 07963B
but like i said, i don't think it's the original engine
yes sonny, it's an
tenticles Offline
#7 Posted : Saturday, 31 May 2008 9:25:55 PM(UTC)
tenticles
hi mr J
so, i dont have the ADR plate or
but like i said, i dont think its the original engine
Mr.Jones Offline
#8 Posted : Saturday, 31 May 2008 10:09:47 PM(UTC)
Mr.Jones
I was after the one on the motor, pass side next to the water pump
Aug 72 is HQ, HZ would start around Qx890xxx or so
Leroy
Voltaire
tenticles Offline
#9 Posted : Saturday, 31 May 2008 10:21:10 PM(UTC)
tenticles
hi leroy
that's the number off the pad on the engine block
QT204811
behind the alternator, above the oil pump but below no. 2 plug
appreciate your assistance
tenticles Offline
#10 Posted : Saturday, 31 May 2008 10:21:10 PM(UTC)
tenticles
hi leroy
thats the number off the pad on the engine block
QT204811
#11 Posted : Saturday, 31 May 2008 10:28:05 PM(UTC)
Date code is on the flat surface between the valley and the water pump, towards the passengers side. On that engine will look like G152 or something like that.
If we all had the same (good) taste
#12 Posted : Saturday, 31 May 2008 10:28:05 PM(UTC)
Date code is on the flat surface between the valley and the water pump, towards the passenger's side. On that engine will look like G152 or something like that.
#13 Posted : Saturday, 31 May 2008 11:28:00 PM(UTC)
Up till some time in 1972 Holden blocks used the US date code so G152 is 15/7/72. The example you give of 30/11/73 will be 30L3 as by that time the Australian form of the date was used. I'm not sure if the August or September 1972 blocks will be US or AUS
#14 Posted : Saturday, 31 May 2008 11:28:00 PM(UTC)
Up till some time in 1972 Holden blocks used the US date code so G152 is 15/7/72. The example you give of 30/11/73 will be 30L3 as by that time the Australian form of the date was used. Im not sure if the August or September 1972 blocks will be US or AUS
tenticles Offline
#15 Posted : Sunday, 1 June 2008 12:12:16 AM(UTC)
tenticles
i'm not sure what i'm supposed to be looking at but...
there is a casting mark on the block ( above the waterpump ) which reads " H2 2 " with what looks like a clock with a pointer pointing at 3 o'clock
tenticles Offline
#16 Posted : Sunday, 1 June 2008 12:12:16 AM(UTC)
tenticles
im not sure what im supposed to be looking at but...
there is a casting mark on the block ( above the waterpump ) which reads " H2 2 " with what looks like a clock with a pointer pointing at 3 oclock
#17 Posted : Sunday, 1 June 2008 12:14:43 AM(UTC)
2/8/1972.
tenticles Offline
#18 Posted : Sunday, 1 June 2008 12:26:25 AM(UTC)
tenticles
many thanks byron and mr jones
i really appreciate the knowledge that is imparted on this site
tenticles Offline
#19 Posted : Sunday, 1 June 2008 12:26:25 AM(UTC)
tenticles
Guest (5)
This page was generated in 0.147 seconds.
