WBLJE Offline
#1 Posted : Monday, 2 June 2008 4:34:17 AM(UTC)
WBLJE
looking at a red vb v8 to put into my wb one tonner.does any one know what the rules are seeing as the motor is a couple of years earlier than the ute.is it alright to have providing all wb pollution gear is used.....cheers
WBLJE Offline
#2 Posted : Monday, 2 June 2008 4:35:12 AM(UTC)
WBLJE
im in queensland by the way........
#3 Posted : Monday, 2 June 2008 5:04:57 AM(UTC)
Pollution requirements on early WB is the same as VB ie ADR27A.
WBLJE Offline
#4 Posted : Monday, 2 June 2008 5:41:29 AM(UTC)
WBLJE
is the 6 cyl flywheel/clutch and starter motor interchangable onto the 253.
#5 Posted : Monday, 2 June 2008 6:16:36 AM(UTC)
No. Gearbox input shaft is different too. So is V8 clutch pedal.
To convert WB 1tonner 6cyl manual to V8 manual you will need:
Engine with HQ-WB mounts and sump/pickup;
V8 radiator;
V8 input shaft and clover for gearbox;
V8 cable Bellhousing;
V8
hztonner Offline
#6 Posted : Monday, 2 June 2008 5:23:55 PM(UTC)
hztonner
hi dude i may have some parts you need and you may hve some parts i need may do
trade i am in (QLD)
just ring me on (5426-7621 ask allan)
old fart racing the older i get the faster i was
WBLJE Offline
#7 Posted : Tuesday, 3 June 2008 5:14:20 AM(UTC)
WBLJE
thanks allan ill give you a call soon.
hztonner Offline
#8 Posted : Wednesday, 4 June 2008 3:17:31 AM(UTC)
hztonner
hi just lettig you know i am home at this time i have
been away if you have tred calling me
cheers allen
hztonner Offline
#9 Posted : Wednesday, 11 June 2008 4:58:18 AM(UTC)
hztonner
hi dude i miss place your number can you give me a call
about the diff and the mounts it is just can not find your number
cheers allen
