looking at a red vb v8 to put into my wb one tonner.does any one know what the rules are seeing as the motor is a couple of years earlier than the ute.is it alright to have providing all wb pollution gear is used.....cheers
im in queensland by the way........
Pollution requirements on early WB is the same as VB ie ADR27A.
is the 6 cyl flywheel/clutch and starter motor interchangable onto the 253.
No. Gearbox input shaft is different too. So is V8 clutch pedal.
To convert WB 1tonner 6cyl manual to V8 manual you will need:
Engine with HQ-WB mounts and sump/pickup; V8 radiator; V8 input shaft and clover for gearbox; V8 cable Bellhousing; V8 |
hi dude i may have some parts you need and you may hve some parts i need may do trade i am in (QLD) just ring me on (5426-7621 ask allan)
old fart racing the older i get the faster i was |
thanks allan ill give you a call soon.
hi just lettig you know i am home at this time i have been away if you have tred calling me cheers allen
hi dude i miss place your number can you give me a call about the diff and the mounts it is just can not find your number cheers allen
