Hey people , want to find out if a vk and vn power steering racks are the same and if not wheres the difference.
MONARO!!WHERE!!NICE |
Not the same.
Very different in fact - the height of the VN is a lot shorter, so the VK steering shaft won't reach it.
It also won't bolt up to a VK crossmember, as the mounts are spaced differently.
If you explain what you are trying to achieve, |
Not the same.
Very different in fact - the height of the VN is a lot shorter, so the VK steering shaft wont reach it.
It also wont bolt up to a VK crossmember, as the mounts are spaced differently.
If you explain what you are trying to achieve, I |
Just checking , i picked up a vk roller to use for speedway but have foundout it has a vn k frame and power rack in it. If the racks were interchangable id keep for a spare but as its different i may as well sell or swap it for a vk one.
MONARO!!WHERE! |
The VN rack is a much better option (and do-able with a VN K-frame and VL steering shaft). Throw the VK rack away, or trade it for a spare VN one :-)
A lot of people a |
As Mick has pointed out the VN rack and Vl steering shaft, works well. Did this on one of my students car . we used the whole column from the vl as well ( couldnt find a vk light switch ).
As Mick has pointed out the VN rack and Vl steering shaft, works well. Did this on one of my students car . we used the whole column from the vl as well ( couldn't find a vk light switch ).
