monaro mark Offline
#1 Posted : Friday, 6 June 2008 10:48:32 PM(UTC)
monaro mark
I was wondering if anyone could tell me if HG 308s used a Saginaw or a M21? Also, were 4spds optional on HG 308 Kingswoods and Premiers and if so, would anyone have a rough idea of how many were produced?
Mark
[email protected]
HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim
HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Black Trim
#2 Posted : Friday, 6 June 2008 11:06:28 PM(UTC)
sag
yes
dunno
#3 Posted : Friday, 6 June 2008 11:07:15 PM(UTC)
In HK-HG M21 was the option code for a 4speed Saginaw. You could also get a wider ratio M22 Saginaw for at least some of HK-HG. The Saginaw box ended with the last of the HG's. In Australia this was late 1971 in any 4 speed HG ute or van (HG commercials w
Edited by user Friday, 6 June 2008 11:12:55 PM(UTC)  | Reason: Not specified
#4 Posted : Friday, 6 June 2008 11:07:15 PM(UTC)
In HK-HG M21 was the option code for a 4speed Saginaw. You could also get a wider ratio M22 Saginaw for at least some of HK-HG. The Saginaw box ended with the last of the HGs. In Australia this was late 1971 in any 4 speed HG ute or van (HG commercials we
tripple webers Offline
#5 Posted : Friday, 6 June 2008 11:08:18 PM(UTC)
tripple webers
I remember the local Vet bought one brand new, it was a Red HG Kingswood 308 4 speed fitted with a saginaw gearbox, and they were available in Premiers. I have no idea how many were made, my guess is they would be a very RARE car.
monaro mark Offline
#6 Posted : Friday, 6 June 2008 11:47:53 PM(UTC)
monaro mark
Thanks guys. I have a few more questions:
1) Could a HG Kingswood/Premier be optioned with a GTS parts such as the dash, steering wheel, guards, bonnet, wheels trims, etc?
2) Could a HG Kingswood/Premier be optioned with power windows or steering?
#7 Posted : Friday, 6 June 2008 11:53:37 PM(UTC)
1. dash and wheel trims for sure, not sure about st wheel. not guards/bonnet
2. yes
3. v8 or 6 cyl shows in vin, for t/g, same as monaros eg 80837 cf 80737
monaro mark Offline
#8 Posted : Saturday, 7 June 2008 12:07:45 AM(UTC)
monaro mark
Ok cool thanks. So there is no way to check if its an original 253 or a 308? Only that its a V8? Well apart from obviously the engine (308H).
Mark
[email protected]
HQ GTS 4 Monaro 30
Edited by user Saturday, 7 June 2008 12:10:27 AM(UTC)  | Reason: Not specified
#9 Posted : Saturday, 7 June 2008 12:10:44 AM(UTC)
yeah i doubt it, unless you have some other documentation or make guesses from the diff/fuel tank etc
monaro mark Offline
#10 Posted : Saturday, 7 June 2008 12:31:26 AM(UTC)
monaro mark
Righto thanks
Mark
[email protected]
#11 Posted : Saturday, 7 June 2008 1:23:26 AM(UTC)
If it's a 308 manual it should have a 10-bolt and hump. A 253 will only have a banjo and hence no hump. In HG you can also pick the V8 4speed from V8 auto in all variants except GTS350 by the speedo cable hole.
#12 Posted : Saturday, 7 June 2008 1:23:26 AM(UTC)
If its a 308 manual it should have a 10-bolt and hump. A 253 will only have a banjo and hence no hump. In HG you can also pick the V8 4speed from V8 auto in all variants except GTS350 by the speedo cable hole.
monaro mark Offline
#13 Posted : Saturday, 7 June 2008 1:33:29 AM(UTC)
monaro mark
Do utes have the 10 bolt hump? Whats the difference between the auto and manual speedo cable holes?
Mark
[email protected]
#14 Posted : Saturday, 7 June 2008 1:47:13 AM(UTC)
If the ute was a 308 manual it will have a hump for the 3.36 10-bolt. Saginaw and V8 powerglide (GTS350A only in HG had a powerglide) use a speedo cable hole over towards the centre of the firewall, basically below the wiper motor. Trimatic is over the ot
#15 Posted : Saturday, 7 June 2008 1:49:02 AM(UTC)
couldnt you option a 10 bolt on a 2fiddy3 byron?
has a hump if it has a 10bolt
manual in middle of firewall, auto on rhs of booster
#16 Posted : Saturday, 7 June 2008 2:07:53 AM(UTC)
To be honest I'm not sure, but i've never seen one. I doubt many would ever have existed especially outside GTS. Warren will know better.
If we all had the same (good) taste, who would buy all th
#17 Posted : Saturday, 7 June 2008 2:07:53 AM(UTC)
To be honest Im not sure, but ive never seen one. I doubt many would ever have existed especially outside GTS. Warren will know better.
If we all had the same (good) taste, who would buy all the
#18 Posted : Saturday, 7 June 2008 2:14:24 AM(UTC)
yeah, definitely odds-on bet or better to be 308 even if it was an option on 53
monaro mark Offline
#19 Posted : Saturday, 7 June 2008 2:38:37 AM(UTC)
monaro mark
Hmmm, is the hump visible from the top of the tub or only from underneath? So does every 308 4 speed HG ute have a 10 bolt?
Mark
[email protected]
#20 Posted : Saturday, 7 June 2008 2:55:52 AM(UTC)
i know of really nice 308 4spd HG Kingswood, white red trim, ive been trying to buy the car for my own collection for some time, but the price keeps going up.
Also I know of a light mettalic green HT or HG prem wagon with white roof, im not sure which,bu
This page was generated in 0.110 seconds.
