rodders Offline
#1 Posted : Saturday, 7 June 2008 8:27:13 AM(UTC)
rodders
Guys, what parts from the HK power steering was made specifically for the Aussie car and how much came from the states ie the power ram looks like a corvette one to me. Any ideas guys? If I can't get an original one with the big bracket the ram works off etc I'm going to have to make a system up that suits....
Rod
#2 Posted : Saturday, 7 June 2008 5:48:25 PM(UTC)
The only US part would be the ram itself. The drag ling is different between V8 and 6 and the idler arm and bracket are also different.
Warren
edelbrock1 Offline
#3 Posted : Saturday, 7 June 2008 6:34:07 PM(UTC)
edelbrock1
What about the pump and brackets for the chev Warren?? surely the pump would have been an import as well??
#4 Posted : Sunday, 8 June 2008 11:50:47 AM(UTC)
I have a power steering setup that was in the boot of a brougham I bought back in 81 as a roller, the guy had taken the 307 out for a skiboat. I put a 283 in it but never worried about the power steering
would this be original fitting on HT brougham?
shifty350 Offline
#5 Posted : Monday, 9 June 2008 7:02:18 AM(UTC)
shifty350
All, only the frame mounting components, 6 cylinder pump brackets/braces, steering connecting rod and hoses are local parts. Pumps, control valve assembly and ram were all Saginaw from the U.S.
Hope this helps.
shifty350 Offline
#6 Posted : Monday, 9 June 2008 7:02:18 AM(UTC)
shifty350
All, only the frame mounting components, 6 cylinder pump brackets/braces, steering connecting rod and hoses are 'local' parts. Pumps, control valve assembly and ram were all Saginaw from the U.S.
Hope this helps.
