zakrasm Offline
#1 Posted : Sunday, 8 June 2008 5:13:51 AM(UTC)
zakrasm
Hi everyone. I'm getting stuck into the rebuild of my LJ and am tossing up between a couple of engine choices. First up is a LS1/LS2 and factory 6 Speed. I like this option because I can get a written off late model car with everything I'll need including a low k motor. It is also easy to make huge power without opening up the engine. Second is a RB30T with Supra 5 speed. I like this because I already have a couple of V8 powered cars and it would be a bit of a change, still plenty of power available but a bit more work to be done engine wise. Any one have any ideas/experiences with either of these combos. Car will be driven regularly on the street so reliability and handling is important. Thanks in advance
#2 Posted : Sunday, 8 June 2008 6:35:02 AM(UTC)
you might want to check with your RTA to see what is legal before spending the money.I would think the six would be the easier option.
#3 Posted : Sunday, 8 June 2008 7:06:01 PM(UTC)
What about a late model 190kW Alloytec and 5 speed auto?
80737k Offline
#4 Posted : Sunday, 8 June 2008 9:00:50 PM(UTC)
80737k
265 Hemi (even a 245) in a Torry has to be an exciting prospect and even left stock, that Torry would be a misile.
This swap has been done plenty enough times which should make it easy enough to find and correspond with someone who's got one or at least
Fossil fuels are YUMMY !
80737k Offline
#5 Posted : Sunday, 8 June 2008 9:00:50 PM(UTC)
80737k
This swap has been done plenty enough times which should make it easy enough to find and correspond with someone whos got one or at least d
boom Offline
#6 Posted : Sunday, 8 June 2008 10:11:27 PM(UTC)
boom
definitely go with the LS1/LS2. if possible go with the L98, they are about $4500 from holmart, and have more potential than the other LSx engines in holdens. its in the intake ports.
In cubes we trust.
