Would appreciate any help with the paint code for "Machine Black" or the correct paint colour for the engine bay & boot. Thank's, Frank. Edited by user Monday, 9 June 2008 2:56:16 AM(UTC)
| Reason: Not specified
There isn't really a correct colour from what Warren has indicated before. It's Warrigal black mixed with whatever was left over from the previous shift. Very early HK GTS Monaros had gloss Warrigal black engine bays but later it became a satin finish.
There isnt really a correct colour from what Warren has indicated before. Its Warrigal black mixed with whatever was left over from the previous shift. Very early HK GTS Monaros had gloss Warrigal black engine bays but later it became a satin finish.
_ |
Thank's Byron, happy to go with the satin finish.
Cheer's, Frank.
Thanks Byron, happy to go with the satin finish.
Cheers, Frank.
Can I ask for some more help with Body Tags & Firewall stamps, please.
Big Tag - HK569A-03597B = HK Prem Sed Auto 03597 Brisbane, what does 03597 mean? 3597th Prem? Trim - 1162-12T = Yulunga Maroon (no inserts). Paint - 587-10686 = Burgandy Metallic.
3597th HK from the Brisbane plant (this is the BODY number).
5041st vehicle from the Brisbane plant since 1/1/68.
HK04711BB - just a sequence number for HK bodies from Brisbane. Is actually the chassis number. In a perfect world should be the same a |
Thanks Byron, Glad you guys reply to these questions, amateur sleuthing & guessing only goes so far...
Thank's Byron, Glad you guy's reply to these questions, amateur sleuthing & guessing only goes so far...
