BLAKE_HQ Offline
#1 Posted : Tuesday, 10 June 2008 9:55:02 AM(UTC)
BLAKE_HQ
On my 308, i am having some problems getting fuel to the carby. Please help...
I automatically thought it was the fuel pump so pulled it off and broke it down, it appeared very clean and in good condition, the diaphram was flexible and not hard at all despite the motor's potentially long sitting time (not sure how long it was sitting for before i bought it). So i put it in a bucket of fuel and just using my hand, i could somewhat move the arm and it pumped plenty of fuel through no worries. I could also see a shiny metal face on the arm from the cam. So i put it back in.
I then turned my attention to the rest of the fuel system. I could suck fuel up getting no air through the lines just using my mouth so i assume the rest of the line (pickup, line etc.) back to the tank is fine.
I then tried to start it once more with the fuel line disconnected at the inline filter - just behind the pump. Putting my finger on the end of the fuel line leading into the fuel pump and onto the carby, there was no suction from the pump on my finger. So i am back at the fuel pump!
Can anyone please suggest what to look for before i pull the pump out again. Or any other places to look?
While i didnt look at it in great detail last time i removed it, the fact it worked in the bucket said to me it should work. Please help... i put some fuel in the carby direct and it popped a couple of time so i know its ready to start - just need some fuel to replenish it.
HKPremier Offline
#2 Posted : Tuesday, 10 June 2008 10:16:58 AM(UTC)
HKPremier
This sounds to me like the fuel pump isnt being activated when it is suppose to be. So have a look where the fuel pump meets the side of the block there should be a plate and behind that make sure there is a pump rod, which pushes on the lever of the fuel
My Cars
1968 HK Premier 186s Original
1968 HK Premier 307 Chev
HKPremier Offline
#3 Posted : Tuesday, 10 June 2008 10:16:58 AM(UTC)
HKPremier
This sounds to me like the fuel pump isn't being activated when it is suppose to be. So have a look where the fuel pump meets the side of the block there should be a plate and behind that make sure there is a pump rod, which pushes on the lever of the fue
My Cars
#4 Posted : Tuesday, 10 June 2008 5:57:45 PM(UTC)
Hi Guys.
HKPremier is referring to Chev V8s. The 308 fuel pump operates directly. Its off a cam, bolted to the front of the cam sprocket.
It sounds like the cam bolt may have come loose & let the little cam rotate . You might have to remove the wat
#5 Posted : Tuesday, 10 June 2008 5:57:45 PM(UTC)
Hi Guys.
HKPremier is referring to Chev V8s. The 308 fuel pump operates directly. It's off a cam, bolted to the front of the cam sprocket.
HKPremier Offline
#6 Posted : Tuesday, 10 June 2008 8:49:17 PM(UTC)
HKPremier
Sorry about that. Hope you find the problem...
My Cars
My Cars
BLAKE_HQ Offline
#7 Posted : Wednesday, 11 June 2008 7:55:55 AM(UTC)
BLAKE_HQ
no luck yet, checked the lines right through to the carby but the pump just isnt pumping...
dont know what to do coz when i pulled it out again it works fine on the bench.
#8 Posted : Sunday, 15 June 2008 6:26:48 AM(UTC)
Hi jim here ,,try to bypass it with an electrical pump to get you going ,put another one on ,if the other one fails id say Warrens got it right!(again! good work)..ps i always run an electric holley blue/red fuel pump to save my battery and starter motor!
