cage000 Offline
#1 Posted : Wednesday, 18 June 2008 7:21:01 AM(UTC)
cage000
thought when i done a fix-ya-up job on the coolant temp sensor plug it fixed it. the car was running good for a few trips then started playing up again. not sure if its the plug,lead,dirty connections.put a new temp sensor in today. still not running good. put the foot down and it dies and sounds like its flooding.
FastEHHolden Offline
#2 Posted : Wednesday, 18 June 2008 7:56:00 PM(UTC)
FastEHHolden
Start by looking at what codes the ECU is flashing at you.
cage000 Offline
#3 Posted : Thursday, 19 June 2008 5:58:45 AM(UTC)
cage000
done all the tests and nothing came,played with the sensor lead, still not running good.played with the lead going to the air flow meter. taking it to holden tommorrow and hopefully they can find the problem. cant understand why it ran good when i played
#4 Posted : Thursday, 19 June 2008 6:14:10 AM(UTC)
My money is on air flow meter, not cheap
#5 Posted : Thursday, 19 June 2008 6:46:20 AM(UTC)
FastEHHolden
If you have a multimeter pull the plug off the airflow meter and test the resistance between the no 1 and no 6 pins....dig the placky plug out and adjust it to 375 ohms.
cage000 Offline
#6 Posted : Thursday, 19 June 2008 7:00:24 AM(UTC)
cage000
put another air flow meter on. it did run good for a while. maybe it is that plug. do u think that the mixture might need adjusting or the plug itself.
mmazz30 Offline
#7 Posted : Thursday, 19 June 2008 8:13:01 AM(UTC)
mmazz30
Did you replace the terminals on the coolant sensor plug?
Most of the VL plug connections corrode and get high resistance no matter how good it may look.
coolant sensor,distributor plug,IAC plug,AF meter notorious for this.
cheers..mario
Cant reme
Edited by user Thursday, 19 June 2008 8:19:19 AM(UTC)  | Reason: Not specified
mmazz30 Offline
#8 Posted : Thursday, 19 June 2008 8:13:01 AM(UTC)
mmazz30
cheers..mario
Can't rem
cage000 Offline
#9 Posted : Thursday, 19 June 2008 9:21:56 AM(UTC)
cage000
i replaced the coolant sensor. the plug on the lead itself is a bit dodgy. when u put it on it seems a bit loose. went to wreckers today and his was worse.unless one of the wires isnt connecting properly.the other option is gettin a auto electrician to ma
Guest (5)
