What would be the general time frame for a HJ engine to match the general build date for a vehicle. ie If the vehicle was built mid January would the block cast be very early January or in December? How far apart could the build date of the car vary from the casting date of the block? Thanks
Normally the same month, but sometimes a month earlier. Of course Chev powered examples are different.
Thanks Byron, do you know where the blocks were cast? In Melbourne? I would assume if that were the case, vehicles assembled in Sydney, Brisbane and Adelaide may have had a longer time frame from casting to installation in the vehicle.
Dr Terry and Warren are the history buffs and will tell you for sure, but AFAIK Holden engines were assembled at Fishermans Bend, Melbourne. I don't think there was much delay between casting date and despatch to plant. Sometimes engines do get delayed an Edited by user Friday, 20 June 2008 6:24:58 PM(UTC)
| Reason: Not specified |
Dr Terry and Warren are the history buffs and will tell you for sure, but AFAIK Holden engines were assembled at Fishermans Bend, Melbourne. I dont think there was much delay between casting date and despatch to plant. Sometimes engines do get delayed and Edited by user Friday, 20 June 2008 6:24:58 PM(UTC)
Hi Guys.
The engine plant is in Fishermans Bend, Melbourne, Victoria. At that time the vehicle assembly plants were in Dandenong (Melbourne, Vic), Pagewood (Sydney, NSW), Acacia Ridge (Brisbane, Qld), Mosman Park (Perth WA) & the current one in Elizabe |
I think its been said, that when the red motors were made, they were not stock piled. but made directly when needed for the car ordered, as it was to come down the assembly line? why have i seen so many motors that the cyl head was cast before the block.
I think it's been said, that when the red motors were made, they were not stock piled. but made directly when needed for the car ordered, as it was to come down the assembly line? why have i seen so many motors that the cyl head was cast before the block.
1. I have a dude saying he has v8 holden, with a replacement block eng, with a prefix "SL xxxxxx," made on 19/5/99. he has its part no.92062264?
2. Did the VL V8 motor come
1. I have a dude saying he has v8 holden, with a replacement block eng, with a prefix "SL xxxxxx," made on 19/5/99. he has it's part no.92062264?
HI all sorry to bother you all i own a hj sandman ive had for 23 years and just purchased a hx sandman and would like to know how i can find out if the 253 motors are original i have been told they are but not sure how to tell cheers kev
rocka |
rocka |
contact holden customer assist... supply you vin and engine number and they can verify for your HJ as they hold records after hq71
thanks for info i,ll chase them up cheers kev
rocka |
rocka |
