musksell Offline
#1 Posted : Sunday, 22 June 2008 1:48:43 AM(UTC)
musksell
does anyone know whether T400 has the same mounting point (cross member) as T700. This is for HQ-Z tonner
I'd think they be close.
#2 Posted : Sunday, 22 June 2008 2:06:17 AM(UTC)
TH350 is what you want. Get one off an early WB Statesman and narrow it.
musksell Offline
#3 Posted : Sunday, 22 June 2008 2:59:13 AM(UTC)
musksell
sorry Byron
worded question a bit wrong, I have a T400 and a CRS cross member, I rang CRS and they not sure ...seriously..!
but I now want to put a T700 in, because of the overdrive ratio.
thanks in advance.
adam PERTH Offline
#4 Posted : Sunday, 22 June 2008 4:05:50 AM(UTC)
adam PERTH
i think i T400 and T700 should go close to the same on the crossmember..
#5 Posted : Sunday, 22 June 2008 4:49:38 AM(UTC)
just run slots in the crossmember,that;; fix that
#6 Posted : Sunday, 22 June 2008 10:36:55 PM(UTC)
AFAIK the TH700 mount is up under the box like a TH350 or V8 powerglide not at the back like a TH400 or trimatic. That is why you need an outrigger on the front of the crossmember like a TH350 one from a late HZ or early WB. Simply cutting slots in the st
musksell Offline
#7 Posted : Tuesday, 24 June 2008 6:00:41 AM(UTC)
musksell
thanks for that Byron, if you do read this Dr terry do you remmeber how long drive shaft was ....cheers in advance.
clubby677 Offline
#8 Posted : Tuesday, 1 July 2008 4:25:07 AM(UTC)
clubby677
I have a HZ tonner with 253 & T700 I got a cross member from CRS (30mm box section )it is the same as T350 and drops down in the middle as the mount is under the box, if you go the T400 the box will hit the hump i would say.
He who dies with the most t
He who dies with the most toys wins!
musksell Offline
#9 Posted : Tuesday, 1 July 2008 5:25:34 AM(UTC)
musksell
thanks for that clubby, I've got that same cross member, so that should be ok. Still curious about the drive shaft length, I have a turbo shaft I think its 1625mm.
musksell Offline
#10 Posted : Tuesday, 1 July 2008 5:25:34 AM(UTC)
musksell
thanks for that clubby, Ive got that same cross member, so that should be ok. Still curious about the drive shaft length, I have a turbo shaft I think its 1625mm.
clubby677 Offline
#11 Posted : Tuesday, 1 July 2008 6:25:13 AM(UTC)
clubby677
I got the original shortend about 25mm but the butcher cut it to short so now have to get a new ond done from scratch i think.
musksell Offline
#12 Posted : Wednesday, 2 July 2008 6:34:07 AM(UTC)
musksell
My crossmember is actually 40mmm square tubing....might be Adrian seelmeyers one..?
musksell Offline
#13 Posted : Wednesday, 2 July 2008 6:34:07 AM(UTC)
musksell
My crossmember is actually 40mmm square tubing....might be Adrian seelmeyer's one..?
clubby677 Offline
#14 Posted : Wednesday, 2 July 2008 7:45:35 AM(UTC)
clubby677
Mine could be , I will put the tonner up on the hoist tommorow maybe and measure how long the tailshaft should be , I may go a two piece one instead ,has anyone got any ideas on the two piece?
clubby677 Offline
#15 Posted : Saturday, 5 July 2008 7:56:32 PM(UTC)
clubby677
The tail shaft be 1590mm at a quick measure
