emufriedchicken Offline
#1 Posted : Wednesday, 25 June 2008 5:50:01 AM(UTC)
emufriedchicken
I was undoing my high pressure line from the power steering pump and the large 1" fitting came out with the oil line. When this came out of the pump a plunger or something like one popped out too. Can anyone out there tell me wich way this goes back into the pump as it fits both ways but the ends are totally different. One end had like a flat surface and the other has like a nut on it.
Tim
trubluhq Offline
#2 Posted : Wednesday, 25 June 2008 6:42:58 PM(UTC)
trubluhq
OK here goes. Refer to HQ service Manual Volume 2.
The only hose with a nut is the outlet. There appears to be a cylindrical shaped rod that fits inside the nut/union for the hose. The rod is hollow to allow fluid thru it. One end of the rod has a smal
#3 Posted : Wednesday, 25 June 2008 8:08:37 PM(UTC)
Hi Guys.
This plunger is the flow control valve. Its direction is very important.
In order. the spring goes in first, then the plunger (NUT END TOWARDS THE SPRING), then screw in the outlet fitting. The flat end of the plunger butts up to the outlet
#4 Posted : Wednesday, 25 June 2008 8:08:37 PM(UTC)
Hi Guys.
In order. the spring goes in first, then the plunger ('NUT' END TOWARDS THE SPRING), then screw in the outlet fitting. The flat end of the plunger butts up to the outl
#5 Posted : Thursday, 26 June 2008 5:48:15 PM(UTC)
emufriedchicken
Thanks Dr Terry thats exactly the info I was looking for.
Tim
This page was generated in 0.022 seconds.
