maccaq Offline
#1 Posted : Wednesday, 25 June 2008 11:45:22 PM(UTC)
maccaq
I have read all the previous posts about teh right carb for a 253 red. - if there is any fresh advice please let me know.
A couple of mates bought me the Holley 570(vac. sec.)with Edelbrock performed for my b-day. Fitted it but still not running right. Goes well with 4 barrels open but crap when cuising around. I don't haev the heart to swap to a Quady or back to the WW as I go back a long way with these mates(btw they are both Ford nuts).
JBM Offline
#2 Posted : Wednesday, 25 June 2008 11:49:12 PM(UTC)
JBM
Where are you located?
Try to find an "Old School" tuner and get it jetted properly.
James
maccaq Offline
#3 Posted : Wednesday, 25 June 2008 11:59:58 PM(UTC)
maccaq
James,
Located in inner west of Sydney.
JBM Offline
#4 Posted : Thursday, 26 June 2008 12:09:24 AM(UTC)
JBM
Dr Terry runs Bebco at Auburn. Phone 9644 2888.
That should be close to you.
James
#5 Posted : Thursday, 26 June 2008 2:30:37 AM(UTC)
The best thing to do really (although you say you don't wish to) is get a Quadrajet off a blue 253, rebuild it and you'll be happier.
If we all had the same (good) taste, who would buy all the Fo
#6 Posted : Thursday, 26 June 2008 2:30:37 AM(UTC)
The best thing to do really (although you say you dont wish to) is get a Quadrajet off a blue 253, rebuild it and youll be happier.
If we all had the same (good) taste, who would buy all the Ford
JBM Offline
#7 Posted : Thursday, 26 June 2008 4:22:58 PM(UTC)
JBM
Another thing you might need to look at is your vacuum system and dizzy advance, because you said it was a bit rough while cruising, which is when the vacuum is low.
An old school tuner you could also use is a guy named Kevin at Tech Tune in Thornliegh
#8 Posted : Tuesday, 1 July 2008 6:15:12 AM(UTC)
Im not a real big fan of the avenger series carbs in your case it may just need jetting up a little from the std #54 jets to #57 jets like the original 465cfm holley as the 570cfm is really a 465cfm carb do the measurments and thats what they are. like th
This page was generated in 0.065 seconds.
