HotRodder Offline
#1 Posted : Tuesday, 1 July 2008 10:44:38 AM(UTC)
HotRodder
Lets say an engine was fully rebuilt and then sat unused for
10 years would the piston rings need replacing or could
they still be used without any problems.
#2 Posted : Tuesday, 1 July 2008 10:59:34 PM(UTC)
If the bores are still clean and new looking then the assembly lube has done it's job and preserved them and probably the rings too.
If you are worried pull the pistons out and inspect the ring faces for rust or pitting.
#3 Posted : Tuesday, 1 July 2008 10:59:34 PM(UTC)
If the bores are still clean and new looking then the assembly lube has done its job and preserved them and probably the rings too.
HotRodder Offline
#4 Posted : Wednesday, 2 July 2008 10:49:29 AM(UTC)
HotRodder
The engine had never been apart and yes the cylinders
are as shinny as new. I see what the new set of rings
cost first before I replace them.
