Hello,
First post!
Picking up what I assume is a 72 Belmont 6 cyl ute.
Couple of questions though:
1. What numbers should match with an HQ, between
- the number physically stamped on the chassis rail - the (vin?) number part of the code on the compliance plate - the (serial) number part of the long tag
2. Trim I take to be Antique Brown. But I'm not familiar with the paint code? Any ideas? (..? maybe a digit missing where shown)
BODY IDENTIFICATION PLATE MODEL 80180QR BODY No 29345-S TRIM ?900-19A PAINT 568-?0046
COMPLIANCE PLATE 3/72 CHQ29491S
LONG/SMALL TAG 8018QH721828 |
___________________________ WTB: - HQ-WB(?) bench seat 4-speed shifter - HQ-WB ute rear window - HQ-WB standard rims - HQ-HX coupe front windscreen mouldings - HQ-HX coupe door mouldings (the stainless one running along top of door exterior) |
It is a 6cyl HQ Belmont ute as you say, built in the Pagewood (Sydney) plant. That early in the HQ run the only numbers that match are the number on the chassis which is reproduced on the ADR tag ie CHQ29491S. Trim 19A is Antique Brown vinyl bench seat.
Hello Byron,
Thanks for taking the time to confirm about which numbers to check for match.
Great to see another place where gents such as yourself and Warren are posting. Only discovered it today. Been reading through the posts on here and there a |
Hi Guys.
Yes, TRIM '900' & PAINT '568-0046' is correct for Mercury Red. This was one of the reds used for the PMG fleet.
Dr Terry |
Hi Guys.
Yes, TRIM 900 & PAINT 568-0046 is correct for Mercury Red. This was one of the reds used for the PMG fleet.
Dr Terry |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
Hi Guys.
568-8181 is Kodak Yellow.
What makes this car a Sandman ?
Not much. I think that is why Leroy put Sandman in quotation.
another panel van with an older code http://cgi.ebay.com.au/H...WDVWQQrdZ1QQcmdZViewItemthe trim line is 1657-22A paint 568-10831 thanks Leroy |
