Do the VN style V8 heads fot the old non EFI 308/253 block? would i have to change the cam? cheers dan |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
They fit on a 308 block, but I think the valves hit the deck of a 253 although they will bolt on. Yes you need a new cam as a few of the valves have swapped position in the head so the lobes have to move too.
___________________________________________ |
You will need new exhaust manifolds as well as the vn heads are evenly spaced and the old heads are not.
You would need a new inlet manifold for the same reasons.
It all starts to add up.
Rock n Roll |
Rock n Roll |
