#1 Posted : Saturday, 5 July 2008 1:16:41 AM(UTC)
hi all.
i have a cleveland v8, from what i can tell it has 2V heads but am not sure if it is 302 or 351??? Engine number is AL4KTG 52870K any help on what it is would be appreciated thanks.. brad
#2 Posted : Sunday, 6 July 2008 7:43:56 PM(UTC)
25 year old engine numbers are pointless regarding displacememnt. Drop the sump and have a look youirself,that way there can be no guessing.
#3 Posted : Friday, 11 July 2008 5:11:45 AM(UTC)
Or remove a spark plug and check your stroke.
coopers308 Offline
#4 Posted : Saturday, 26 July 2008 9:47:13 PM(UTC)
coopers308
Check the casting number on the block, i think its on the drivers side on an upside down pad you can only see from under the car or with a mirror. If your sure it's only a 2V a 351C will probably have number like DOAZ-D.
sly376 Offline
#5 Posted : Monday, 15 September 2008 4:01:33 AM(UTC)
sly376
As stated above the best way to tell is remove engine sump and turn your crank over till you see 302 or 351, I have seen engines that claim to be a 351 & there were 302 crank and rods sitting in it!
snappa Offline
#6 Posted : Monday, 15 September 2008 4:48:04 AM(UTC)
snappa
Why not take out a sparkplug and measure the stroke
351 ZH
351 ZH
#7 Posted : Monday, 15 September 2008 11:12:31 PM(UTC)
Snappa's way is easiest 3.00" for a 302 or 3.5" for a 351. Easily distinguishable with a piece of wire down a spark plug hole.
If at first you don't s
Edited by user Monday, 15 September 2008 11:13:28 PM(UTC)  | Reason: Not specified
Paull Offline
#8 Posted : Monday, 29 September 2008 4:08:20 PM(UTC)
Paull
AL4KTG 52870K is from an August 1977 F100 4 wheel drive. AT that time, you could only get a 5.8 Litre Cleveland engine. Therefore, it should be a 351, but you have to check at any rate. Snappa's way is the easiest
