ozgeek Offline
#1 Posted : Tuesday, 8 July 2008 12:04:17 AM(UTC)
ozgeek
My car is a second-hand 1999 Holden Commodore VT Series 2 Executive station wagon. I've owned it since last year. It clocks at over 200,000km but still runs great (abiet getting new drive belt soon).
Anyway, recently the indicators have been strange. When I flick the indicator lever up or down, the light outside does not flash or does flash but at different rate. Might be fast or slow or steady on. If I turn the hazard mode on (the button that turns on all the indicators), they flash as normal as if they are fine.
What could be wrong? I am not really familar with cars but am learning.
Blue ballz Offline
#2 Posted : Tuesday, 8 July 2008 2:32:32 AM(UTC)
Blue ballz
Do all your indicator light work when the hazards are on?
Edited by user Tuesday, 8 July 2008 2:33:34 AM(UTC)  | Reason: Not specified
ozgeek Offline
#3 Posted : Tuesday, 8 July 2008 3:53:44 AM(UTC)
ozgeek
Yes. When I press the hazard light button on the dash, all the indicators do flash normally as if they are working fine - regular flashing and at good intervals.
It's just that when I use the indicators to do turns in normal driving that sometimes it d
ozgeek Offline
#4 Posted : Tuesday, 8 July 2008 3:53:44 AM(UTC)
ozgeek
Its just that when I use the indicators to do turns in normal driving that sometimes it do
Blue ballz Offline
#5 Posted : Tuesday, 8 July 2008 7:07:55 AM(UTC)
Blue ballz
In my limited experience as i am only starting my vehicle mechanic apprentice is to check that all the lights are in securely. It doesn't explain why the lights stay on though, but does suggest you are getting a short.
Blue ballz Offline
#6 Posted : Tuesday, 8 July 2008 7:07:55 AM(UTC)
Blue ballz
In my limited experience as i am only starting my vehicle mechanic apprentice is to check that all the lights are in securely. It doesnt explain why the lights stay on though, but does suggest you are getting a short.
#7 Posted : Tuesday, 8 July 2008 10:46:29 AM(UTC)
Id be looking for a separate flasher can that runs just the indicators.
If it has one, this will be the fault.
#8 Posted : Tuesday, 8 July 2008 10:46:29 AM(UTC)
I'd be looking for a separate flasher can that runs just the indicators.
#9 Posted : Tuesday, 8 July 2008 7:15:09 PM(UTC)
Hi ozgeek.
From memory they use the same flasher relay for the blinkers as they do for the hazard flashers.
My guess is the blinker switch itself is faulty. Ive replaced many of these on cars with similar symptoms.
#10 Posted : Tuesday, 8 July 2008 7:15:09 PM(UTC)
Hi ozgeek.
My guess is the blinker switch itself is faulty. I've replaced many of these on cars with similar symptoms.
ozgeek Offline
#11 Posted : Tuesday, 8 July 2008 8:53:42 PM(UTC)
ozgeek
Thank you very much. I will relay that to my dad.
Blue ballz Offline
#12 Posted : Wednesday, 9 July 2008 5:34:53 AM(UTC)
Blue ballz
If the wiring is as the same at a vs the hazards are wired in to the indicators and cant work without the hazards plugged in.
Blue ballz Offline
#13 Posted : Wednesday, 9 July 2008 5:34:53 AM(UTC)
Blue ballz
If the wiring is as the same at a vs the hazards are wired in to the indicators and can't work without the hazards plugged in.
Guest (5)
