#1 Posted : Thursday, 10 July 2008 2:13:30 AM(UTC)
Hi there, where is the engine number on a red 6
#2 Posted : Thursday, 10 July 2008 2:16:49 AM(UTC)
Engine number is stamped into a pad located on the side of the block near the oil pump/engine mounting boss. It is really obvious if the engine is degreased but if you cant find it then most likley it has been removed.
#3 Posted : Thursday, 10 July 2008 2:16:49 AM(UTC)
Engine number is stamped into a pad located on the side of the block near the oil pump/engine mounting boss. It is really obvious if the engine is degreased but if you can't find it then most likley it has been removed.
#4 Posted : Thursday, 10 July 2008 3:03:22 AM(UTC)
Also note it is hard to see on a black (VK) engine as the pad is rought cast and not machined like everything before it.
#5 Posted : Thursday, 10 July 2008 3:29:20 AM(UTC)
Byron, I must be simple but I thought Phill was asking about red 6 engines. I, like many others on this forum, am impressed by your Knowledge of Holdens, but lets not respond in a confusing and unrelated manner just to get another star. A black 6 is an ev
#6 Posted : Thursday, 10 July 2008 4:04:30 AM(UTC)
anthony,
be quiet
ok bye
David Offline
#7 Posted : Thursday, 10 July 2008 4:26:40 AM(UTC)
David
Well said Brett.
Anthony, you got the first bit right - you are simple!
David
#8 Posted : Thursday, 10 July 2008 5:23:06 AM(UTC)
Normally I ignore anonymous posters but "Anthony" is correct and Im happy to wear the critisism for my error. I was thinking with blinkers on and missed the "red 6" which was blatantly in front of me. I was simply thinking "holden 6" ie red, blue, black.
#9 Posted : Thursday, 10 July 2008 5:23:06 AM(UTC)
Normally I ignore anonymous posters but "Anthony" is correct and I'm happy to wear the critisism for my error. I was thinking with blinkers on and missed the "red 6" which was blatantly in front of me. I was simply thinking "holden 6" ie red, blue, black.
#10 Posted : Thursday, 10 July 2008 5:41:25 AM(UTC)
Byron, I sincerely apologise for the remark regarding the star/s. There are a number of us here on a friend's computer and some idiot in the background was looking at the author column and said something out loud about all the stars.
HKfacts, Pagewood
#11 Posted : Thursday, 10 July 2008 5:41:25 AM(UTC)
Byron, I sincerely apologise for the remark regarding the star/s. There are a number of us here on a friends computer and some idiot in the background was looking at the author column and said something out loud about all the stars.
HKfacts, Pagewood g
#12 Posted : Thursday, 10 July 2008 6:09:47 AM(UTC)
Anthony, there was no need to apologise. I did look like an idiot on the surface as I totally misread the original post. Why dont you and your mates register and log on. It only takes a second or two. You will find that if you keep using an anonymous logi
#13 Posted : Thursday, 10 July 2008 6:09:47 AM(UTC)
Anthony, there was no need to apologise. I did look like an idiot on the surface as I totally misread the original post. Why don't you and your mates register and log on. It only takes a second or two. You will find that if you keep using an anonymous log
David Offline
#14 Posted : Friday, 11 July 2008 6:42:23 PM(UTC)
David
Aw, now you blokes have made me feel bad for being nasty.
Anthony, I'm sor... sor... sor.... The word just won't come out!
I apologise Anthony.
David
David Offline
#15 Posted : Friday, 11 July 2008 6:42:23 PM(UTC)
David
Anthony, Im sor... sor... sor.... The word just wont come out!
David
#16 Posted : Saturday, 12 July 2008 6:21:01 AM(UTC)
Its so easy.
Im sorry...there...all problems fixed
#17 Posted : Saturday, 12 July 2008 6:21:01 AM(UTC)
Its so easy.
I'm sorry...there...all problems fixed
#18 Posted : Saturday, 12 July 2008 9:24:30 PM(UTC)
thanks fellas, even though i asked about the red six, the additional bit about the black motor was also appreciated.
#19 Posted : Saturday, 12 July 2008 9:24:30 PM(UTC)
thanks fella's, even though i asked about the red six, the additional bit about the black motor was also appreciated.
Guest (10)
