Hi there, where is the engine number on a red 6
Engine number is stamped into a pad located on the side of the block near the oil pump/engine mounting boss. It is really obvious if the engine is degreased but if you cant find it then most likley it has been removed.
Engine number is stamped into a pad located on the side of the block near the oil pump/engine mounting boss. It is really obvious if the engine is degreased but if you can't find it then most likley it has been removed.
Also note it is hard to see on a black (VK) engine as the pad is rought cast and not machined like everything before it.
Byron, I must be simple but I thought Phill was asking about red 6 engines. I, like many others on this forum, am impressed by your Knowledge of Holdens, but lets not respond in a confusing and unrelated manner just to get another star. A black 6 is an ev
Well said Brett.
Anthony, you got the first bit right - you are simple!
David
Normally I ignore anonymous posters but "Anthony" is correct and Im happy to wear the critisism for my error. I was thinking with blinkers on and missed the "red 6" which was blatantly in front of me. I was simply thinking "holden 6" ie red, blue, black. |
Normally I ignore anonymous posters but "Anthony" is correct and I'm happy to wear the critisism for my error. I was thinking with blinkers on and missed the "red 6" which was blatantly in front of me. I was simply thinking "holden 6" ie red, blue, black. |
Byron, I sincerely apologise for the remark regarding the star/s. There are a number of us here on a friend's computer and some idiot in the background was looking at the author column and said something out loud about all the stars.
HKfacts, Pagewood
Byron, I sincerely apologise for the remark regarding the star/s. There are a number of us here on a friends computer and some idiot in the background was looking at the author column and said something out loud about all the stars.
HKfacts, Pagewood g
Anthony, there was no need to apologise. I did look like an idiot on the surface as I totally misread the original post. Why dont you and your mates register and log on. It only takes a second or two. You will find that if you keep using an anonymous logi |
Anthony, there was no need to apologise. I did look like an idiot on the surface as I totally misread the original post. Why don't you and your mates register and log on. It only takes a second or two. You will find that if you keep using an anonymous log |
Aw, now you blokes have made me feel bad for being nasty.
Anthony, I'm sor... sor... sor.... The word just won't come out!
I apologise Anthony.
David
Anthony, Im sor... sor... sor.... The word just wont come out!
David
Its so easy.
Im sorry...there...all problems fixed
Its so easy.
I'm sorry...there...all problems fixed
thanks fellas, even though i asked about the red six, the additional bit about the black motor was also appreciated.
thanks fella's, even though i asked about the red six, the additional bit about the black motor was also appreciated.
