Guys
Been trying to sort this out.
Found a 308N the other day, and also recently heard of a 186NxxxxS.
Does this mean for example the 253's were 253NxxxxH, 253NxxxxL?
One would assume so Byron.
Warren
What about 161 engines? As the difference was in the head not the pistons would there have been a 161NxxxxH and 161xxxxL or just a 161N? I was talking about this a while back with Dr Terry, and am just interested if anyone has seen any engines like this? |
I have heard that the replacement engines were supplied without an engine number. It was up to the motor registry authorities or police to supply a number when the vehicle was presented for inspection. I have never seen an engine with the numbers you ment
I have a 1972 cast date 308N engine recorded, and have seen a 186NxxxxS. The 308 was obviously built in 1972
i may have mentioned to byron before, i had a 308NxxxS, aussie pattern about 6 months ago mid - late seventies casting from memory.
He who hesitates, -Masturbates. |
Are you sure it had an S on the end? The S should only exist for a variant away from standard eg 186S. As there was only one 308 in HT/G there would be no need for a suffix.
It may then be true that the original engines built pre HQ/LC numbering syste |
