t-dog Offline
#1 Posted : Thursday, 17 July 2008 10:46:17 PM(UTC)
t-dog
old mate wants to stroke his 308 with COME kit reckons stock vn heads are the way to go as well any thoughts guys?
also how and what would you need in regards to inlet manifold to run as a carby setup? are there extractors available to run this set up on hj - hz?
totally awesome web site by the way great work guys!!!
ooowwww yeh! thats what im talkin bout!
#2 Posted : Thursday, 17 July 2008 11:07:13 PM(UTC)
good setup, use harrop intake, pipes from pacemaker ph5500 is part number, carby depends on man auto etc
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
bundybluedog Offline
#3 Posted : Friday, 18 July 2008 7:55:36 AM(UTC)
bundybluedog
whats the diferance between vn to vs v8 heads or are they the same. my brother inlaw was going to go the VS SS engine in his HX, he paid a guy at grunt automotive in clontarf brisbane who took his origanal 308 and all the goodies aswell as $3800 and left
boom Offline
#4 Posted : Friday, 18 July 2008 11:45:09 AM(UTC)
boom
all heads from VN to VS are identical.
ive heard bad stories about procomp. a guy was telling me that the crank is junk, and that when e took it to get balanced the guy said it was impossible.
i have heard of cranks from china being ok, but not for hold
#5 Posted : Saturday, 19 July 2008 2:36:59 AM(UTC)
anyone else have reports on the quality or otherwise of the procomp stroker kits ?
#6 Posted : Saturday, 19 July 2008 2:43:34 AM(UTC)
Have a talk to COME about them. I know they are competition, but just listen and weigh up what they say.
#7 Posted : Tuesday, 22 July 2008 4:37:45 AM(UTC)
bundybluedog
were do i get one of these eagle 355 kits
boom Offline
#8 Posted : Tuesday, 22 July 2008 5:47:09 AM(UTC)
boom
high performance world, rocket, i know that they are $1100 for a complete kit.
for a basic motor, the eagle kit is the cheapest way to do it. even if you get stuff from the US.
Once you go H-beams, and forged pistons for a 450hp+ setup you should star
Steve_in_Adelaide Offline
#9 Posted : Tuesday, 22 July 2008 8:30:48 AM(UTC)
Steve_in_Adelaide
I was at a BBQ on Friday night at a local machine shop. There were several engine builders and mechanics...
No one had anything good to say about procomp.... Several stories about how much weight had to be taken off their cranks to make them balance...
Aqua HQ GTS 350 Coupe
White SS Hatchback Torana 355
HQforme Offline
#10 Posted : Tuesday, 22 July 2008 10:33:21 AM(UTC)
HQforme
You guys do realise you get what you pay for right?
Parts like Procomp are, generally speaking, ok for general use. Some parts are of course a safer bet than others. If its high performance youre after, you need better gear, and you pay for it.
Stre
"Silly modern cars"
HQforme Offline
#11 Posted : Tuesday, 22 July 2008 10:33:21 AM(UTC)
HQforme
Parts like Procomp are, generally speaking, ok for general use. Some parts are of course a safer bet than others. If it's high performance you're after, you need better gear, and you pay for it.
St
"Silly modern cars"
boom Offline
#12 Posted : Tuesday, 22 July 2008 12:26:18 PM(UTC)
boom
im not saying the procomp stuff wouldnt work, but it would definitely be shaking itself apart when it ran, due to the imbalance in counterweights.
In cubes we trust.
#13 Posted : Tuesday, 22 July 2008 7:58:15 PM(UTC)
Procomp is garbage, just coz street machine built one, How long will it last? The coke can alloy heads go soft, they flow no better than iron vn heads and the cranks are garbage.
Ive heard of 2 eagle cranks failing too.
I have a come 355 kit, never
#14 Posted : Tuesday, 22 July 2008 8:01:14 PM(UTC)
In reply to the OP, iron vn/vs heads, stock valved and opened up a touch, redline single plane manifold (fit easy under the bonnet), 750 vac sec. and pacemaker 1 3/4 try y pipes. Cam around 230 degrees at 0.050 and itd be an awesome streeter.
#15 Posted : Thursday, 24 July 2008 6:33:00 AM(UTC)
Steve_in_Adelaide
I just found this on youtube....
http://www.youtube.com/w...60mGazx0&feature=related
Note the amount of holes in the crank counter weights... they have removed an aweful lot of metal to get this sucker to balance...
Aqua HQ GTS 3
