HotRodder Offline
#1 Posted : Friday, 18 July 2008 11:16:52 AM(UTC)
HotRodder
Does anyone know what parts of a 308 can be used in a 253.
Have you hugged an English Bull Terrier today
boom Offline
#2 Posted : Friday, 18 July 2008 11:33:58 AM(UTC)
boom
crank, rods. crank wont be balanced for the 253 pistons though.
In cubes we trust.
boom Offline
#3 Posted : Friday, 18 July 2008 11:34:53 AM(UTC)
boom
also heads unless they are big valve heads. and manifold. and all other bolt ons
In cubes we trust.
JBM Offline
#4 Posted : Friday, 18 July 2008 4:31:06 PM(UTC)
JBM
The 308 crank counterweights are too heavy for the 253 rods and pistons as mentioned above.
A 253 bore is 3.625" and the 308 is 4" so pistons arent interchangeable. Stroke is the same.
James
Edited by user Friday, 18 July 2008 6:09:52 PM(UTC)  | Reason: Not specified
KiwiHQ Offline
#5 Posted : Friday, 18 July 2008 5:59:17 PM(UTC)
KiwiHQ
All bolt on parts. Inlet manifold, dizzy, waterpumps, sumps, cams, oil pumps, lifters, pushrods, rockers, rocker covers... almost everything except, as mentioned, crank, pistons and rods. I am not 100% on the heads either.
Rock n Roll
Rock n Roll
#6 Posted : Friday, 18 July 2008 6:10:46 PM(UTC)
The whole lot minus the crank and pistons. And as Boom says, really big valve heads will hit the deck but standard ones are fine (not VN though as they are big valve). 308 carby will need either primary or secondaries changed too (cant remember which).
#7 Posted : Friday, 18 July 2008 6:10:46 PM(UTC)
The whole lot minus the crank and pistons. And as Boom says, really big valve heads will hit the deck but standard ones are fine (not VN though as they are big valve). 308 carby will need either primary or secondaries changed too (can't remember which).
HotRodder Offline
#8 Posted : Sunday, 20 July 2008 1:26:52 AM(UTC)
HotRodder
When you say VN head is that the VN Commodore head
I'm surprised it would fit the 308, is it the same
size and shape as the 308.
HotRodder Offline
#9 Posted : Sunday, 20 July 2008 1:26:52 AM(UTC)
HotRodder
Im surprised it would fit the 308, is it the same
#10 Posted : Sunday, 20 July 2008 2:26:03 AM(UTC)
Yes VN-VSIII V8 heads bolt straight onto HT-VL 253/304/308 blocks, but the valves hit the deck of the 253 due to smaller bore.
This page was generated in 0.066 seconds.
