peterwmh Offline
#1 Posted : Friday, 18 July 2008 7:15:59 PM(UTC)
peterwmh
Hi all,
Not on my Holden, but on my 4WD Toyota 60 series Landcruiser. In the last week this vehicle has gone from a start brilliantly first go on gas even on the coldest morning to a hard starting (takes about 5 minutes cranking usually firing then stalling) and when finally running idles OK but splutters down the road and finally picks up about 5 mins later! It seems to not even run on petrol at all now, that used to work fine too! The gas system is only 1 year old! I've done the points and plugs, the leads may be a bit old, any other ideas?? Thanks Peter
JBM Offline
#2 Posted : Friday, 18 July 2008 7:20:02 PM(UTC)
JBM
Does it have a water supply to the converter that may be clogged? The cold LPG will freeze the water in the convertor if theres not enough flow going through.
James
You only have to be in fron
#3 Posted : Friday, 18 July 2008 7:24:41 PM(UTC)
Agree^^
#4 Posted : Friday, 18 July 2008 7:40:57 PM(UTC)
They need mixture tuning about once a year I find. Change the plugs every time you change the oil. I switch back to petrol every evening and start on petrol first thing to get some circulatio going through the regulator before flicking over to gas. Even o
#5 Posted : Friday, 18 July 2008 8:00:50 PM(UTC)
How long ago did you change the points?
They might have closed up.
peterwmh Offline
#6 Posted : Friday, 18 July 2008 8:39:42 PM(UTC)
peterwmh
Thanks all, OK I'll check the water supply, and the points about 2 months ago, I'll check those too! I'd switch it to petrol last thing if it would run on petrol, that used to be fine too, but now it won't run on it at all!!
Peter
202 and
Edited by user Friday, 18 July 2008 8:42:56 PM(UTC)  | Reason: Not specified
peterwmh Offline
#7 Posted : Friday, 18 July 2008 8:39:42 PM(UTC)
peterwmh
Thanks all, OK Ill check the water supply, and the points about 2 months ago, Ill check those too! Id switch it to petrol last thing if it would run on petrol, that used to be fine too, but now it wont run on it at all!!
Peter
202 and thr
meecar Offline
#8 Posted : Friday, 18 July 2008 8:57:17 PM(UTC)
meecar
it could be the little black box in your car that switches petrol/gas i found on a few cars i've had its done the same thing and it was the box for some reason
meecar Offline
#9 Posted : Friday, 18 July 2008 8:57:17 PM(UTC)
meecar
it could be the little black box in your car that switches petrol/gas i found on a few cars ive had its done the same thing and it was the box for some reason
#10 Posted : Friday, 18 July 2008 10:45:12 PM(UTC)
If there was a lack of coolant entering the converter the car would still start as normal but the converter would freeze and the car die a few minutes later when it freezes up.
I lost all of my coolant about 6 months ago (middle of summer) and the c
#11 Posted : Saturday, 19 July 2008 1:55:41 AM(UTC)
i agree with the frozen converter theory ive been on gas for 18 years next time it plays up have a look at the converter it will be covered in frost and the water that suppose to go through it will be frozen till it thaws it will run like a hairy goat
mackv8 Offline
#12 Posted : Saturday, 19 July 2008 6:20:09 AM(UTC)
mackv8
are you using shell LPG if so it may be most of your LPG problems go to there web site for details as they are or have had problems in the last 2 to 3 months with there LPG
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
mackv8 Offline
#13 Posted : Saturday, 19 July 2008 6:20:09 AM(UTC)
mackv8
are you using shell LPG if so it may be most of your LPG problems go to there web site for details as they are or have had problems in the last 2 to 3 month's with there LPG
mmazz30 Offline
#14 Posted : Saturday, 19 July 2008 6:41:50 AM(UTC)
mmazz30
Pete also check for ducting that has come loose.Make sure all joins and connections to the carb is sealed well.
cheers...mario
peterwmh Offline
#15 Posted : Saturday, 19 July 2008 6:53:28 AM(UTC)
peterwmh
Thanks, yes I nearly always use Shell LPG, the carb appeares to be well sealed also. Cheers Peter
202 and three on the tree, cant get more Aussie than that!!
peterwmh Offline
#16 Posted : Saturday, 19 July 2008 6:53:28 AM(UTC)
peterwmh
This page was generated in 0.080 seconds.
