#1 Posted : Monday, 21 July 2008 7:14:34 AM(UTC)
ive bought a set of straight cuts for a 351 clevland and the cam gear has no timing mark on it i was told as long as the engine was timed and all the marks lined up on the original gears b4 i took of the old timin it should just go on because they only go on one way is this true or what can i do
[x/d]
Edited by user Tuesday, 22 July 2008 4:43:55 AM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 22 July 2008 4:48:04 AM(UTC)
hey mate, Sounds good to me, you could use a degree wheel but like they say if its timed already wack em on. aint nothin stoppin you from centre punching on your own marks if you are so inclined.
